Page 10 of 20
Re: new 5/6 plate clutch for lambrettas
Posted: Fri Jun 17, 2011 7:36 pm
by handofdave
any more updates on availability?been getting desperate and started to look at the usual dealers clutches again but want to avoid a 2nd mortgage
cheers
Posted: Fri Jun 17, 2011 7:56 pm
by rocho68
handofdave wrote:any more updates on availability?been getting desperate and started to look at the usual dealers clutches again but want to avoid a 2nd mortgage
cheers
hi dave , again sorry for the delay , pm me with the details of what you need and what spec engine you run , mark whos running the dac has now fitted the finalised design and it will be run this saturday followed by the rally to ireland next week , i have recieved a small quantity of my steels that i ordered so i can get on with machiing some up , i also have photos to go on the site tomorrow of my new "normal power " lambretta clutches again sorry for the delay !!
Posted: Sun Jun 19, 2011 7:32 pm
by mark
took scoot out today and did around 75-85 miles at all speeds and conditions (town and dual carrigeway), i even held it for 10-12 miles at 85mph and i found this clutch as good as i hoped it would be , its as easy to pull in as a std and can cope with as much grief as you can give it.
i am amazed by the ease of how it handles all thats thrown at it.
thanks lee :P
roll on ireland as the final test 8-)
Posted: Sun Jun 19, 2011 8:24 pm
by joespeed
cheers
hello rocha68.
mark has just put a report on here about the clutch and i would like to order a couple if you can supply them,
regards
joe
Posted: Wed Jun 22, 2011 12:32 pm
by rocho68
heres my new "normal power" clutch (cr2) which is aimed at standard to mildly tuned bikes , it currently being fitted to my 24 bhp engine so we will see what happens ! , i think pricewise you will be looking at around £150 , as for by 6 plate full power (cr1) im currently sorting the first ones out :D
Posted: Wed Jun 22, 2011 5:10 pm
by Rich_T
Looks smaller than RS125 plates and 8 tabs.
Are these clutches now based of Lifan 125cc Monkey bikes parts like the Siagon one?
Posted: Wed Jun 22, 2011 10:09 pm
by soullad
Lee,
would they work with a standard Li type plunger / chaincase set -up.
Ian
Posted: Sun Jul 17, 2011 9:25 pm
by mark
quick update i pulled my motor today to change the drive side oil seal and thought i would check the clutch out while i was in the motor, i am pleased to say there was no wear at all after a very hard 600 miles on final finished unit
roch68's clutch after 600 miles with no wear by mark & anne's photos, on Flickr
on a by note the readspeed 6 plate i was running needed changing after 500 miles as it was worn out , saying that jerome did say that its not designed for a 40bhp motor so i was happy to change as and when i needed to.
Posted: Fri Oct 07, 2011 12:54 pm
by corrado
Any updates on these?
Posted: Fri Oct 07, 2011 3:32 pm
by rocho68
corrado wrote:Any updates on these?
hi corrado , after several problems with supply / home etc im finally back up and running , there are some new design features which include an all new cast aluminium basket currently being made to my design , a new lazer cutter is also in place as the last one proved to be slightly unreliable !
as for the five plates , i have a few now in tuned bikes with no issues that im aware of and the 6 plates in the dac lambrettas , so fingers crossed everything now will start progressing !!!
cheers lee
