Re: THE NEW DGB LAMBRETTA GEAR BOX
Posted: Tue Nov 24, 2009 7:38 pm
shocky, i think he could be a specialist with rubber belt machines!
regards
joe
regards
joe
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
belts are for girls and hippys :biggrin:Saxman wrote:Get rid of the gears, put a belt in it
not too sure about this belt thing, charlie edmonds couldn't catch one at cadwell!DMC wrote:belts are for girls and hippys :biggrin:Saxman wrote:Get rid of the gears, put a belt in it
Nice one Smifffy. THAT'S why you're such a great bloke to share a beer with.....RinB wrote:Was going to call it THE LIGHTSIDE![]()
drunkmunkey6969 wrote:What the fcuk ever happened to all this gearbox development?
Quite frankly i never cared about 5 gears, but a 4 speed box that was lighter and stronger than original, with close ratios was what i wanted....any news or is it all dead in the water?
You'll need an electric starter and a way to seperate the oil from the crank case too.sean brady scooters wrote:i think its only a matter of time before someone developes a twist and go set up/conversion for a lammy.
all thats needed is a variator, on the end of the crank,centrifugal clutch,belt to match and a couple of cogs in gearbox.............
I still have an eye on it but there are a load of other things I need to sort out first, new GT barrels, EFi, small scratch built water brake dyno etc. For the time being the current boxes will cover the majority of applications.sydduckett wrote:drunkmunkey6969 wrote:What the fcuk ever happened to all this gearbox development?
Its gone the same way of the mb 5-speed and the SIP lambretta speedo........often wanted, never seen...
