Page 9 of 20
Re: lambretta 290 rotax
Posted: Sat Jul 29, 2017 6:59 pm
by holty
hi garry , i thought you might recognize it, it off an rb 20 barrel so im using the rb reeds.
Posted: Sat Jul 29, 2017 7:14 pm
by holty
heres a pic of the barrel packer plate and a couple of pics of the carb fitted
ImageIMG_1069 by stephen holt, on Flickr
ImageIMG_1071 by stephen holt, on Flickr
ImageIMG_1070 by stephen holt, on Flickr
Posted: Sat Jul 29, 2017 7:40 pm
by garry inglis
you have plenty clearance there and i remember now when you first started this that you were using the rb reed thats a good idea on the end plate as well have you had a look at casa lambrettas new 18 spline layshaft /8 stud hub /bearing and other bits only about £280 should really strengthen the back end up
Posted: Fri Aug 04, 2017 7:08 pm
by holty
a couple more pics, ive added a bump stop
ImageIMG_1094 by stephen holt, on Flickr
ImageIMG_1095 by stephen holt, on Flickr
Posted: Fri Aug 04, 2017 7:27 pm
by garry inglis
I wondered about the bump stop and suspension travel very clever👍
Posted: Fri Aug 04, 2017 7:35 pm
by garry inglis
A lot of welding are you not worried about porosity and air leeks remember my ts230 casing that leaked like a sieve
Posted: Sat Aug 05, 2017 9:19 pm
by holty
garry inglis wrote: ↑Fri Aug 04, 2017 7:35 pm A lot of welding are you not worried about porosity and air leeks remember my ts230 casing that leaked like a sieve
good point, the guy who did the welding said it wasnt easy, i wont find out for sure till i do a leakdown test, nice to meet you today gary, its always good to put a face to a name, your ts1 sounded spot on and was worth the hard work you had building it
Posted: Sat Aug 05, 2017 10:07 pm
by RManson
A leakdown test is necessary for not only the inlet, but also to ensure there is no coolant leaking into the crankcase, etc.
Posted: Sun Aug 06, 2017 6:24 am
by garry inglis
Yes great to meet you as well holty had a great day out and fun ride back home acting like I stole it lol see you at Bridlington 😎
Posted: Sun Aug 06, 2017 8:49 pm
by holty
RManson wrote: ↑Sat Aug 05, 2017 10:07 pm A leakdown test is necessary for not only the inlet, but also to ensure there is no coolant leaking into the crankcase, etc.
i wont have that problem as my water inlet feed is into the barrel via the hole under the exhaust port, then a packer plate between cylinder and block seal the bottom of the cylinder, well thats the plan.
