With the arrival of some slightly longer screws and a couple of better days, I've been out in the garden, fortunately not gardening (much - I've had to trim that pigging holly).
I've managed to get the final bits of the bloody (literally) floor board runners done.
I've also got the horncast fitted properly, considering this was all together before painting the fit has given me some issues, I had to loosen of the mudguard to get it to fit and then tighten everything up again.
At the backend I've changed the plastic bushes on the R1 shock for ones from Lambretta Upgrades. These fit much better both in the shock and on the mountings.
I've started to work back on the wiring, I've built in a fuse holder and a battery isolator switch, largely because I don't want to replace my expensively renovated original ignition switch with one of the ones that has the extra wire for switching. I've yet to decide how and where I'm going to mount that. I did have a blonde half hour trying to figure out why the brake light was on solid before I remembered I'd not refitted the brake pedal...
I've got the SIP speedo up and running.
It's working in most respects though I did have some problems initially when the bike was running as it was reading 33km/h ticking over on the stand and was a bit flakey in the menus. Doing some reading fitting a resistor plug and cap sorted that.
I've spliced the brown wire into one of the yellows from the stator but still not getting a reading on the rev counters. Not sure what's going on there. It's irritating but not the end of the world for now.
When fitting the legshields I'd taken the brake pedal off so treated it to a wire brushing, a coat of barbecue paint and a new rubber. The wife even lent a hand to tighten the cable!!
I now feel the end is in sight. I even started fitting the badges. Just for comparison here's a Scootopia badge versus a ScootRS one you can draw your own conclusion about which looks and fits better.
Fitting the badges gave my missus an opportunity to take the p155 - she says she knew I'd end up resorting to hitting it with a hammer...
But the legshield badges and sticker are done.
