Page 9 of 9
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 12:27 pm
by Donnie
? but the stub on the imola is round and the mugello is standard oval so youre not comparing like for like there
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 12:41 pm
by drunkmunkey6969
simonwwfc wrote:Why on Muggelo 186 kits is the short black stub fitted and on the Muggelo 200 small block they use the chrome stub any ideas
It isn't?
Imola186/TS1225 etc use the short black/round stub.
Cast Iron, Mugello, Rapido, Avanti etc use the other stub.
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 3:42 pm
by simonwwfc
Is it something to do with age of Muggelo kit then ? As mine takes
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 4:07 pm
by tonydevon
thats the normal stub for the muggy kit
my 200 kit was latest version, and uses that shape exhaust port fitting etc
are you confusing muggy and imola?
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 4:14 pm
by shocky
tonydevon wrote:thats the normal stub for the muggy kit
He seems to be
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 4:27 pm
by CPH Lambretta
Simon,
Imola/TS1/Monza use a round exhaust port/flange.
Mugello/standard/rapido/RT all use a oval exhaust port/flange.
Question is why do the makers of the exhaust make the 2 different flanges in 2 different lengths?
What you need is an oval flange that is as short as the round flange, if that makes sense.
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 7:11 pm
by Donnie
simonwwfc wrote:Is it something to do with age of Muggelo kit then ? As mine takes
Which is the shape all mugellos take and always have.
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 7:39 pm
by simonwwfc
CPH Lambretta wrote:Simon,
Correct
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 9:52 pm
by corrado
I'm thinking that getting the manifold cut'n'shut will be the easiest fix.
I've not got one to hand but wondering if you can trim a couple of mm off the stub and off the exhaust pipe to see if it's moving in the right direction?
Re: Taffy copy pipe
Posted: Fri Mar 28, 2014 10:31 pm
by simonwwfc
Il have stub back tomorrow il post pic and see how it goes from there . If no good looks like andy Francis is next stop
