Sportique
gpts1
well it s been a while but, the lil things take time,
LED head lights
Plumbing and wiring of the ignition and ECU are finished
gpts1
Dyno on Thursday. half a day of tuning and setting up the ECU for the ignition.
I can only echo what's already been said, simply stunning work with a lot of well considered engineering. That said, I can't help but think that the ScootRs front brake might be a bit vicious :? That size of the calliper and master cylinder fitted to a Lambretta is tricky especially on loose or wet surfaces so it will be even worse on something as light as a Sportique. A modified Speedfighter master cylinder (Grimeca) might be a little more progressive?
gpts1
thanks for your input coaster, Yes had thought of that but ill see how she goes, and adjust to suit.
C*NTSPEED
Regards to the headlight are they just household gu type led bulbs?
Superb work btw
Sent from my GT-I9300 using Tapatalk 4 Beta
GEMINI S.C.
BLACK WIDDA'S S.C.
C*NTSPEED wrote:Regards to the headlight are they just household gu type led bulbs?
Superb work btw
When I saw them I thought they were the same as these that knowledge used http://scooterotica.org/forum/viewtopic ... t&start=20 but now I'm not so sure, look very 'trick' though.
gaz_powell
the whole thing looks so right and brilliantly (but definitely not) simple which make it so worth while.
the engineering is superb to make a humble sportique so desirable
I`ve always hated bretta forks in vespas as usually they come with hugger mudguards but in this case with the gp turning mudguard it just looks so right.
top job - keep the pictures coming
gaz
ForemanBob
Main scooter: GP RT230
I see that you have the modified bell intake on the PWK... how do you find them... do they make a difference?
gpts1
ForemanBob wrote:I see that you have the modified bell intake on the PWK... how do you find them... do they make a difference?
Dont know yet, but ill let you know soon.
theageofindustry
Main scooter: 74 Vijai Super
Incredible build. Every step seemed to come with an entirely new surprise. Lots of new and creative ideas, and maybe a few I may gleam for myself to use on future builds. Can't wait to see some pics on the road.
