THE NEW DGB LAMBRETTA GEAR BOX
joespeed
the long first gear is ok for solo racers,this would be the the advantage of a 5 speed ,the two up rider can use first gear,the solo racer can set off in second for a long start gear and then close ratios for racing and keeping the motor in the power band.
i have tinno sacchi 5 speed this is quite a good box although i darn,t abuse it ,i had a rospeed box when i was a lad and that spit a tooth of and came through the case,not a good moment.
five speed box
10-12-15-19-21
50-42-39-35-33
i worked out the gears to be stock lambretta items
1.gp200 italian
2.gp200 italian
3.gp200 italian
4.gp150 italian
5.sx200 italian
that gear box plays a very important part on the small single cylinder engine and races are won on the correct selection not just power ,the use of the origional gears on a square or hexagonal tree would enable us to use the old lambretta gear patterns to make a box up to suit your surcumstances.
a four speed box is not going to be that much better than its origional counterpart other than it will be stronger,
regards
joe
chiggy03
Hi Dave, any updates?
J1MS
^^^^^^ Wot he said^^^^^^
RinB
J1MS wrote:^^^^^^ Wot he said^^^^^^
Last Ive heard he's given up :?
twin
well as u no i cut a gearbox for the dacboys,
they did some miles with it in, but it did not last,with 2 teeth for first gear,well i think as THAY HAVE NOT SENT IT BACK TO ME,and its been a long time,
so made one gear for someome with a motorbike out of EN36 as per the stuff that i was going to use for the gearbox,
when he puts it in the fcuking come off,so i dont no what to do now,
all i no is i can cut gears,which i dont think has been done before,
still not got it back ??. i will ask tomorrow when i go down . will report back. have you tried ringing dave?
twin
mark wrote:still not got it back ??. i will ask tomorrow when i go down . will report back. have you tried ringing dave?
Hi
yes i did send him a text,and i have rung chris,but still not sent it back,
understand dave has the broken gear but has mislaid the rest at the mo :shock:
Saxman
Get rid of the gears, put a belt in it
Torque isn't cheap
Saxman wrote:Get rid of the gears, put a belt in it
how would that help :?:
