Page 8 of 9
Re: Delving into VSE1M
Posted: Wed Mar 25, 2015 10:57 pm
by GLscoot
Excellent. Just make sure the flywheel is on tightly & fit the cowls and then let us know if there is still a noise. It just maybe that your clutch cable is just a bit tight and the whirring noise is coming from the clutch.
When I first start a vespa engine from a rebuild I normally squirt neat fuel down the plug, tighten the plug and kick it over.
Posted: Fri Apr 03, 2015 3:46 pm
by storkfoot
I think I'm almost there. I managed to get out for 2 or 3 miles earlier today. No signs of the lurching clutch I had before the engine strip and the whirring noise I had on first kick over was indeed the clutch and appears to have been resolved by tightening up the cable a bit.
I'm still tinkering with the air screw to get the tickover just right but it's almost there.
Remember this is a mostly original Rally 200. The area that concerns me most is the 42 years old loom. The earth connection to the Femsatronic literally disintegrated into powder as I tried to reconnect it (hence the bodge below). If some of the rest of the loom is as perished as this, I suspect there are problems ahead (typical negative thinking scooterist
Posted: Sun Apr 05, 2015 8:07 pm
by storkfoot
I've had a good ride around today, during which I have convinced myself that all is good and the Rally can return to the road in all its glory. A couple of pics to celebate:
Thanks to all who assisted along the way
Posted: Sun Apr 05, 2015 9:02 pm
by gaz_powell
good to see you got there in the end Paul
nice couple of photos
gaz
Posted: Sun Apr 05, 2015 9:05 pm
by rosscla
Looks superb
Posted: Sun Apr 05, 2015 10:24 pm
by storkfoot
Thanks, lads. The photos are Seacombe Ferry and Bidston Observatory, built in 1866 and which predicted the tides for the D- day landings amongst many other things. Since 2000 it has fallen into disarray sadly.
Posted: Mon Apr 06, 2015 6:53 pm
by GLscoot
Excellent & good work.
Posted: Tue Apr 07, 2015 4:15 pm
by cgt75b
It looks great, pleased you got the engine fettled up, hope you have many happy hours riding it, a classic scooter !
Great photo's also, thanks for sharing.
Posted: Tue Apr 07, 2015 11:03 pm
by cartmel808
That's a lovely Rally - truly stunning..... and great to see such an original example running & riding!
Posted: Wed Apr 08, 2015 7:09 am
by bazman
Spot on Paul!!
See you c2c?
