Page 8 of 10
Re: My new project
Posted: Sun Jan 20, 2013 10:54 pm
by carlos fandango
G. lol... im not a footy fan
Clyde. Ill have to have a look for some of that tinter .thanks
Markauk . Good work
some solutions come from the strangest places
Well ive Finally got the engine together, which gave me one problem after another
but its sorted now and in
But now the exhaust is giving me problems arrrggh
Re: My new project
Posted: Sun Jan 20, 2013 11:12 pm
by Toddy
What's up with the pipe Russ?
Re: My new project
Posted: Sun Jan 20, 2013 11:14 pm
by Muppet
Loadsa neat bits on this; i like; have you wired da indicators to work as hazard as well? Cud be useful; What's the exzorst that's causin ya grief and why,
muppet,
Re: My new project
Posted: Sun Jan 20, 2013 11:55 pm
by carlos fandango
The problem with the pipe is , theres only about 10mm between it and the outrigger, and thats with out the nut for the runners
its hitting the outrigger with still another 10mm to go before the bump stop hits the frame
Ill ring the supplier tomorrow and have another play with it.
Re: My new project
Posted: Mon Jan 21, 2013 12:02 am
by Muppet
can ya spin ya barrel a little on the studs anti clock ways as ya look at ya cylinder head from front of bike it'll twist y zorst stub an pipe away from y bords a few mill? It'd have y undo yer head nuts to spin it but what else can y do
muppet,
Re: My new project
Posted: Mon Jan 21, 2013 12:34 am
by carlos fandango
Its an idea, but the bracket would restrict it ? ill have another look at it tomorrow.
Re: My new project
Posted: Mon Jan 21, 2013 2:34 pm
by Muppet
Is it the body or rear of y runna bore catchin on the back cone an stinga? Wot zorst is it?
Re: My new project
Posted: Wed Jan 23, 2013 12:34 am
by carlos fandango
Muppet wrote:Is it the body or rear of y runna bore catchin on the back cone an stinga? Wot zorst is it?
Its a Franspeed super tourer.
I put the rear and main bracket on loosely, fitted the body into the stub and put a spring on the stub to hold it on.
The rear bobbin was 5mm to high to get the bolt through the the hole in the rear bracket. The stinger rear cone had a 10mm gap between it and the rear floor board hanger (without a nut to hold the foot board on) with the shocker off, the hanger hit the pipe with still 15mm to go before the bump stop hit ? Bear in mind this is with just a spring holding the pipe on no bolts yet.
So after a call to Mr F,....... i learnt a few things.... "They have sold thirty with no issues"...."they are made and fitted to a test engine"...."an engine shouldnt hit the bump stop while riding ,so its ok and normal for the pipe to hit the frame first"...".i must have fitted it wrong"....."If im not happy i can send it back for a refund".
Hmmm so i must have fitted the spring wrong then ??? so it was going back......then after having a think, and as i didnt really want to send it back, as id be back to no pipe and time ticking by
i came up with an idea how to "adjust" it to get it fitting better.
Its now on and with 20mm under the hanger, still not quite how id like it but alot better than what it was.
Re: My new project
Posted: Sat Jan 26, 2013 12:56 am
by carlos fandango
Right, got the pipe on
then...... i go to fit the end can, simple job ? take the three nylocs and washers off the three bolts on the end can. The gasket is already on so pop it on through three holes then put the washers on and try the nuts
they wont start on the threads as the (captive) bolts arnt long enough FFS
End cans are quite heavy, and can cause quite abit of damage when thrown in anger
...................Im quite a patient person.... so i resisted the temptation and when and put the Kettle on and had a brew
ten minutes later i went back in and had another look. The washers were thick ones so i swapped them for some thin s/steel ones this gave enough threads to get the nuts on, and take up any slack, and compress the gasket a little. So ive got the three nuts on but the bolts are only just touching the nylon of the nuts
I also managed to start her up today for the first time
just a few jobs left to do and wait for my seat to come back from the trimmers
Re: My new project
Posted: Sat Jan 26, 2013 1:20 am
by Mr G in NYC
Looking good that mate
I like the way the black
looks blue/black.....Is that your Euro steed ? G.
