super monza
tony wrote:Mutley... chill mate. Have a look at the first pics from a customer supermonza.I am not sure why you are SO anti a development in Lambretta tuning?
What?? :shock:
CANbus
rocho68 wrote:
CANbus wrote:Yes blue printing does have a few meanings, if we take it in the context of the thread, it means checking something to a reference point. Designers used to reproduce their drawing on light sensitive paper then produce copies with the aid of an ammonia die/gas, the copied drawings had a blue tinge, then more of yellow tint as time went on.
It sounds like CE checks everything to his original design, good on him. Which could open up a new can of worms however, if something happened CE (god for bid) what happens to the Super Monza?
The term blueprinting on tuning engines refers to makin sure everything is at its optimum , including matching , bearing tolerances ,shims , compression ratios ,infact anything , its closing the tolerances that a producion engine has ,tony scott is well known in motorcycle racing ,his blueprinted engines were more powerfull than the honda racing jap engines ,but it takes a lot of time to do and is not about sticking new parts together , the way i see it is that charlie has cleaned and tweeked the barrel to how he wants it ,to blueprint it i would have thought it would have to go on the exact engine it was goin on , crank in place and all the relevant timings checked etc ,thats my take on it anyway lol !
That's a good explanation also, if all the bits were available.
11111111 = 0xFF
OzOAP
Main scooter: Vespa PTS1E
tony wrote:Oz.... sorry for the 'dissing' but if you are prepared to give it you have to be prepared to take it...
If you are thinking of a sm kit for your p2 then you will have to chat to charley
No need to apologise.
Just read through the post though, can't see where I'm "dissing" (not a word I've ever used before), I'm big enough to take it. In my job you get very thick skin, there is a lot more bitching and jealousy in motorsport than scootering.
I come onto forums to have a laugh, and maybe comment on things I dont agree with. Some people can take it, some cant.
I won't waste Charleys time... he's gonna be a busy man 'blueprinting'
nelson pk
when anything is designed its put on paper called a blueprint, all blueprinting is is something thats made to the original blueprint, no more no less exactly to the blueprint, simple int it
Couldn't have said it better myself!!
Right, last comment on this from scootering page 126 issue April 2010!
I quote " What is Blueprinting".
"blueprinting can have different meanings depending on the person you speak to but as far as i am concerned it refers to refining the product so that it was more like it was supposed to be according to the original drawings or blueprints"
Last quote from Two stroke performance tuning by A Graham Bell.
" Blueprinting is slow tedious work and it can be expensive when crankshafts have to be separated machined and trued or when cylinder heads have to be machined to close up the squish band without raising compression ratio. It is not very exciting work because when you have finished the engine is STOCK STANDARD. THE BASIS FOR ANY SERIOUS TUNING MUST BEGIN WITH BRINGING THE ENGINE UP TO THE MANUFACTURERS SPECIFICATIONS!"
So we are talking about blueprinting a barrel ....so you bring that up to what the original designs were!
Simples!
That is my last comment on it (Hooray i hear say :lol: )
I'm now going to lie down :lol:
nelson pk
God, i need a life! :lol:
OzOAP
OzOAP wrote:...Charley is still using his hands 8-)
My quote above has been taken, (by Tony), as to "dissing" Charley and calling him a w@nk3r.
This is not the case.
I am currently whipping myself with a Lammy 82 link(streched)chain, as penance.
My quote above has been taken, (by 'some' people), as to "dissing" Charley and calling him a w@nk3r.
:shock: :shock: :lol: :lol:
lifes a drag
Simples!
i think thats the first time someone has agreed with what iv seid on here, thanks Nelson PK you have made my day ,,,
psychedelicropcircle
Photographic evidence then allnis forgiven :barfy:
Chris CSPE
A jap blueprinted engine is the hole engine, gaining power from every part of it. Wot will matter is how the hole engine is built and port timings and compression checked when building it. Id have thought that CE biggest concern is how the hole package is put together seeing as everybody's capabilities differ. Two motors with the same speck can be totally different all depending on how it's built blueprinted barrel or not.
