Although I did buy a new rear wheel nut. I realised it wouldn't go on the layshaft. Didn't want to damage anything so I left it as is and used the old one. That one went on without a hassle.
Are they to different thread pitch on the layshafts? Mine is an original innocenti one, on the 1962 TV S3.
Anyone?
Re: TV175 Series 3 -62, restoration
Posted: Tue Jan 15, 2013 8:32 am
by rosscla
Not supposed to be, but I have exactly the same issue with mine. I've had three new nuts from a variety of suppliers and none of them will catch the first thread on the layshaft. Th old one goes on by hand no problem.
Apparently the layshaft thread ( m16x 1.5) is the same as your shock mount so to test it, try to run the nut onto the shock mount, both old and new. I've been told t his means the threads on the layshaft are damaged and that the old nut has been 'worn' in. Both old an new nuts go fine on the shock mount...
I third a thread file but this made not the slightest difference other than it wore the file out.
In the end, I'll replace the layshaft next time the engine is stripped.
Posted: Tue Jan 15, 2013 10:46 am
by kejj
That's actually a very reasonable explanation.
I did buy a new layshaft but since the original seemed to be in a good shape I reused it instead. Will try the new nut on the layshaft and shock mount. My nut catches on but stops after half a turn.
I connected the wires. Not as easy task, I'm barely capable of reading electronic schemes, any less connecting one part to the other. Took me a while before I had all the wires done. All the extra cables I ordered seemed like a good idea then but now only complicated things
There is supposedly an earth cable going to the flywheel cowling. Just don't know which. Don't have any left from stator
