Page 7 of 17
Re: MARK CHRISTIES KWAK 500 S6
Posted: Sat Oct 09, 2010 10:32 am
by Gunny
T5-190 wrote:http://www.zabel-racing.de/en/motors.html
Thats the one I was thinking about, hahaha.
That's just bonkers !! but love it..
You putting Vforce reeds on it ?? expensive but worth it !! Puts my RD on a whole new level and up's the bhp by about another 7-8..
Posted: Sat Oct 09, 2010 10:39 am
by RICSPEED
there pretty small for a 700 ...cool
Posted: Sat Oct 09, 2010 4:40 pm
by C*NTSPEED
RICSPEED wrote:there pretty small for a 700 ...cool
ohhhh and perfect for an ld frame me thinks ;)
Posted: Sat Oct 09, 2010 5:27 pm
by RICSPEED
only thing.... does it have a lighting coil on the genny
Posted: Sun Oct 10, 2010 9:00 am
by T5-190
I see it has a PVL ignition, so I would have thought lighting coils should be available. I can't find a price for a complete engine, but going by the spare parts prices its not going to be cheap.
Posted: Sun Oct 10, 2010 7:49 pm
by T5-190
Got the new engine in today, its not quite the same, I needed to grind a little off here and there. The carb is in a slightly different place and height aswell. This has given me a small ball ache as it is very close to the under side of the tank. A 90' cable entry should do it, but the carb now sits at a strange sideways angle. The old carb rubber only has 4 bolts and the new one has 6, so I will have to make an ally one with normal carb rubber.
Posted: Sun Oct 10, 2010 8:28 pm
by RICSPEED
bugger ..looks tight at the bottom of loop and power valve :(
Posted: Sun Oct 10, 2010 8:46 pm
by Andy Pickering
so what would be the best moto x motor to drop in a lammy..
Posted: Sun Oct 10, 2010 9:13 pm
by RICSPEED
Lam46 wrote:so what would be the best moto x motor to drop in a lammy..
that one :mrgreen:
Posted: Mon Oct 11, 2010 6:48 pm
by T5-190
The frame loop IS very close to the power valve governor. But the engine is a solid mount as is the frame, so nothing goes up or down to rub. But if it does, back out with the grinder. As for an engine choice... I did do a little homework. I knew I wanted a 500cc so choice was not huge. So I went to see a guy I used to work with that had done a lot of beach racing etc. He recommended the KX because the power valve is mechanically driven where all the other 500cc engines are servo driven. With this comes its own problems.
