Page 7 of 7
Re: TV175 1963 strip and rebuild
Posted: Wed Feb 08, 2017 4:25 pm
by fluff34567
Today i patched up a few holes where edge trim and other bolt on things used to be.
Posted: Tue Feb 21, 2017 9:11 pm
by fluff34567
Today i walnut blasted the frame to strip the paint. Frame has cleary been blasted before as it has a rough texture. As it had fine surface rust everywhere I had to spend ages in the oxide machine to strip that... here it is near the end.
https://youtu.be/djlEPbswqNQ
Posted: Thu Feb 23, 2017 6:09 pm
by fluff34567
Frame primed with zinc chromate so a rather fetching puss green.
After a while I'm wishing the blasting cabinet was a bit taller.. oh my back!
Posted: Tue Feb 28, 2017 9:51 pm
by fluff34567
Piston measured today... should be fine but need to check about the ring area dimensions and do the "traditional" way of measuring the cylinder/piston gap.
