Page 7 of 9
Re: NOS TS1
Posted: Thu Nov 26, 2015 1:36 pm
by shocky
Muppet wrote:does the scomadi use stock type dampers?
Do you mean the scooter or scamadi forks ? the scooter uses an outboard shock with a 12mm fixing pin top and bottom like this but these are of my own making
Re: NOS TS1
Posted: Wed Dec 16, 2015 5:19 am
by gpts1
Had a bit of time to get some more machining done, so it is now almost ready to fit into the forks and have a look how I'm going to set up the anti dive on it .
Re: NOS TS1
Posted: Tue Jan 12, 2016 9:22 pm
by gpts1
Hi All, was pretty busy around the house over the Christmas new years break but managed to get the disk into the fork to see what it looks like.
Re: NOS TS1
Posted: Wed Jan 13, 2016 3:49 am
by guygrrr
Very trick! It's nice to see it coming along.
Re: NOS TS1
Posted: Fri Jan 15, 2016 8:44 pm
by rudeboy67
Lovin the work in this keep it up cant wait to see final result !
Re: NOS TS1
Posted: Wed Jan 20, 2016 2:25 am
by gpts1
Re: NOS TS1
Posted: Tue May 31, 2016 2:33 am
by gpts1
have managed to get a little done, but not as much as i would like,
Cylinder shroud was done, then i discovered fan was to far away from the fan cover, so Ive modified that to close up the gap and will be getting the shroud modified to suit.
stripped and detailed my PWK, plus modified it to fit my nitrous injector
Forks were stripped again and new stainless brackets welded in the right place this time
Also added the anti dive bracket as well.
Discovered a small crack in one of the lower fork half's obviously from when they were formed, so that was fixed also.
Forks are just about ready to put back together now after Ive finished remetal finishing them.
Re: NOS TS1
Posted: Thu Jun 23, 2016 9:22 pm
by gpts1
forks are back together, and i done a bit more machining work on the disk brake
Re: NOS TS1
Posted: Thu Jun 23, 2016 9:24 pm
by gpts1
Got all the body panels in primer over the weekend
Re: NOS TS1
Posted: Wed Aug 31, 2016 5:14 am
by gpts1
