Page 7 of 9
Re: SX250LC custom
Posted: Fri Nov 05, 2010 6:00 pm
by sydduckett
RICSPEED wrote:on my wish list
Im sure martin will do you a good price.......oh you mean the clutch....
Re: SX250LC custom
Posted: Fri Nov 05, 2010 7:11 pm
by mark
sef ,they are a true 2 finger clutch with the biting point in the right place at all times, quite a bit of modifcation is done to the inside of the casing but none to the outside ,they use a handmade gear change shroud/sleeve as well so its not cheap but they are woth the money imho
Re: SX250LC custom
Posted: Fri Nov 05, 2010 7:36 pm
by Ruudboy
mark wrote:sef ,they are a true 2 finger clutch with the biting point in the right place at all times, quite a bit of modifcation is done to the inside of the casing but none to the outside ,they use a handmade gear change shroud/sleeve as well so its not cheap but they are woth the money imho
Amen, except for the two finger, which was on my very short dry run not yet that smooth, guess that was because it was just installed.
Re: SX250LC custom
Posted: Sat Nov 06, 2010 1:40 am
by Craig H
I have one one fitted and it is well worth the money.OCD.Oh nearly forgot, love the scoot very nice.
Re: SX250LC custom
Posted: Sat Nov 06, 2010 9:31 am
by mark
check its bled properly as i burnt out a clutch trying to bleed mine when i first fitted it
Re: SX250LC custom
Posted: Sat Nov 06, 2010 9:56 am
by Ruudboy
Thanks for the tip mark, actually Chris already mentioned this in his instructions.
Waiting on some new oil cups to arrive, when we install those, we can easy re-bleed them.
I expect the build to be finished next weekend. Then i have to make up my mind about the airbrushing and decals...
Re: SX250LC custom
Posted: Thu Nov 18, 2010 2:30 am
by Ruudboy
Some new pics, finalizing of the build will be today and tomorrow. I should have it this weekend.
Proper fuel filter
Choke conversion done...
little bit of a wiring mess.... going to remove the sleeving for the tubes...
overflow
custom badge
gauges working and tank empty indicator
advanced retard installed
EGT
I updated servers and forgot i uploaded the pics there, ill try to restore the old pics also.
Re: SX250LC custom
Posted: Sat Nov 20, 2010 2:41 pm
by Ruudboy
Kind of finished... 2 things... 1 the clutch gave out.. its leaking at the activator inside... wrote CS engineering but i dont think it will be solved before next Sunday when we have the only scooter event in Saigon of the year. aaaahhhhhh 2. Still not done any airbrushing etc this is more because i can not make my mind up about it yet. Any way here some pics...
Balance small issues, need to replace one ducati cup with a full size one, done monday, need to replace the coolant liquid with another color, green sucks...
Re: SX250LC custom
Posted: Sat Nov 20, 2010 3:05 pm
by Bilko
Well done. I like it.
Didn't take you long either.
Re: SX250LC custom
Posted: Sat Nov 20, 2010 3:46 pm
by Ruudboy
Wouldn't say 6 months is quick either, credit goes to SSC!
