Page 6 of 7
Re: Question for the engine tuners.
Posted: Sun Nov 29, 2009 2:18 pm
by tony
Knowledge wrote:Well, it's good to see a bit of healthy debate, and it's nice to see that some people actually read to the end of my longer contrubutions.
I don't know Charlie, and he is fairly enigmatic, so perhaps I was wrong to imply that I knew how he worked, but I needed someone to illustrate the computer age of tuning. I know that he uses computers, because Tony told me he did. In fact Tony, you were the one who told me that computer based tuning was THE future. So, back to the offending line....
Frankly, much of his innovation is driven by what his computer is suggesting.
Let me say first that I was not saying that Charlie was incapable of innovation without a computer, so I will clarify this sentence.
If I had a sophisticated computer programme that accurately reflected my previous experiments and complimented the results from the dyno and testing, I would use the programme to make changes to my engine within cyber-space. Now, if my programme told me, say, to lower the primary compression ratio, I would have to look at innovations that would allow me to do this within the rules.
So, the sentence could have been less person-specific, but this is how innovation can be driven by what a computer is suggesting.
Thanks Martin, thatr sounds better. It is no secret that PT is computerised. Its a timesaver. However doing what a computer tells you with our restricted motors doesnt work quite how it appears. its simply not that easy. If it was everybody would have 40hp lambrettas on the track.
Posted: Sun Nov 29, 2009 2:26 pm
by J1MS
There are many more functions that these types of dynos with high frequency boards and transducers can analyze, either on a one cycle basis or at lower frequencies and multi cycle formats. If you search the Two stroke Dyno Forums, there is plenty more info available...
I do think that this is where Scooter tuning will eventually be at, that's if its not already being done today...
PS since doing the little bit of reading I have changed my mind on the crankcase & exhaust port pressures a little, I think my original thoughts were a little out...
Posted: Sun Nov 29, 2009 5:01 pm
by GPMatt
at the end of the day, if the computor software was that good, he wouldnt have to make the pipes in a straight line form to test them and adjust the diffusors and the parralell sections. it's meerly a guide tool and its avaliable to everyone.
Posted: Sun Nov 29, 2009 5:46 pm
by soosh
Why dont people read the book by A.Graham Bell on 2 stroke tuning,surely a lot of questions will be answered in there.Its supposed to be a good book.
Posted: Sun Nov 29, 2009 5:56 pm
by paulmgreen
davidblythe wrote:this thread has all the elements of a Greek play with layers off allegory,
the siren calls, hubris, nemesis, the jouney to Hades
hopefully Zeus is mindful of the role he gives to Hermes
Posted: Sun Nov 29, 2009 9:48 pm
by Knowledge
Just in case anyone is interested, Tony called me tonight (number not withheld) and we had a very civilsed chat and cleared the air. We did not even need to agree to differ. I was surprised to learn that Charlie had got to hear about the thread, so I asked Tony pass on my apologies to Charlie.
So that matter is over. Now where were we ........?
Posted: Sun Nov 29, 2009 9:52 pm
by sean brady scooters
well thats good ,and i am well pleased to hear that we are all friends again...and back to normal....
Posted: Sun Nov 29, 2009 10:07 pm
by Dazza
Knowledge wrote:So that matter is over. Now where were we ........?
Somewhere near Hades
Posted: Sun Nov 29, 2009 10:17 pm
by Knowledge
cezeta wrote:is it you that makes the choke cables and brake cables for jb tuning?
Yes and no. I make choke cables and brake cables. I do not supply them to JB, but I do supply Madspeed and Andy Francis, and I will supply anyone who contacts me, trade or personal.
Thanks for asking.
Posted: Tue Dec 01, 2009 11:19 am
by muttonjeff
J1MS wrote:It seems there are several producers of high tech dynos with the ability for pressure analyzers to be used with many available functions which allow a window into the working cycle of a two stroke engine, I have read up on a few dynos through the Internet...
I was originally looking to see if anyone in the scooter-world had published anything dyno based for crankcase pressures, combustion pressures, and exhaust port pressures on a one cycle basis, as I had already heard of this going on in the other realms of two stroke tuning.
I would have thought the primary pumping pressures would be of around 3-10psi for the crank case at or just after transfers opening.. More of an "uneducated guess"...
Combustion pressures are dependant on compression ratios, ignition timing, cylinder temperature, port timings, so for this reason cylinder pressure would be harder for me to make a calculated guess..
The negative and positive pressure waves reverberating through the expansion chamber effecting exhaust port pressure as the port opens and closes I had an "uneducated guess" at around minus 5-16psi with a reverse pulse peaking at around plus 3 to plus 14psi..
this was my thinking and I was looking to see if anyone had managed to put a tuned Lambretta on a suitable dyno to see if my guesses came close...
As I say just trying to see if my thinking was right but wasn't sure if this was being done in the Lambretta Vespa tuning circles
Here
http://www.tfxengine.com/software8.html" onclick="window.open(this.href);return false; is a link to a Dyno website with some data which explains in fairly good detail in graph form combustion pressure psi, combustion rate/fraction burned and exhaust port pressure psi
The fact I am looking at this stuff Does not make me a tuner I just know it exists and this kind of stuff is way beyond my capabilitys I just like to know how the performance gains could be made...
you have pm
