Re: Lost piston ring peg
Posted: Thu Dec 03, 2015 1:00 pm
So, if the RT pistons are dropping pegs, what are the alternatives for the RT195/225 Cylinders? Asso?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
When I was using asso pistons years ago I used to change the piston every year due to slight cracks showing where Adam described in his post. The one year I didn't bother because I hadn't done so many miles that year I regretted it. Mid way through the next year I had an inlet skirt fall off at high rpm in 3rd gear as I overtook a car which made its way round the crank and broke a 2 inch hole in the crank case just under the bump stop. That's when I stopped using asso pistons.HxPaul wrote:I've got two scooters with Casa kits using Asso pistons,I've had no problems from either.Should I be worried that the piston skirt on either kit will crack at sometime and wipe the engine out.I've done quite a lot of miles on both kits.This year I put a new set of rings on them and didn't notice anything wrong with the pistons...........then again I didn't look for cracking on the skirt.
Ron Moss Mitaka piston 70mm a,b,c,d £70 last time I heard.kejj wrote:So, if the RT pistons are dropping pegs, what are the alternatives for the RT195/225 Cylinders? Asso?
embarrassing too not getting past the boy racers in the carKen Tucky wrote:The things you do to get more air into that engine Eden ....................ha...........ha......
Did you also leave a large skid mark, in your underpants..........................
Scary really on the road eh.
Richard
That's unlikely but if you wrecked the barrel then the replate should be done to match the piston.kejj wrote:Thanks, hope those a,b,c,d correspond to the RT kits A,b,c,d markings.
I have a T shirt with that on.warning we have seen rings wear so much that they have spun over the pegs and blown up at 600 miles!"
