Page 6 of 7
Re: MB 5 speed box.
Posted: Fri Dec 04, 2015 7:45 pm
by drunkmunkey6969
Adam_Winstone wrote:^... cross threaded?
BOOM BOOM!!!
Re: MB 5 speed box.
Posted: Fri Dec 04, 2015 8:07 pm
by Adam_Winstone
BTW - That little bit of humour was your Christmas present so make the most of it.
Re: MB 5 speed box.
Posted: Fri Dec 04, 2015 8:24 pm
by Mr G in NYC
Adam ,
you sure you don't live North of Hadrians wall ??
G.
Re: MB 5 speed box.
Posted: Fri Dec 04, 2015 8:36 pm
by Adam_Winstone
^... Like
Credit goes to Eden... he sets them up and I knock 'em down.
Re: MB 5 speed box.
Posted: Sun Dec 06, 2015 12:00 pm
by Strummer10
Interesting post......'Playing Devil's advocate' what real advantages does a 5 speed box provide over a 4 speed ? Conscious of the cost of buying and fitting one, is there a well earned advantage OR is it marginal . Not looking to knock the 5 speed but wondered if its the way forward ?
Re: MB 5 speed box.
Posted: Sun Dec 06, 2015 1:39 pm
by rosscla
Most people who've had one seem to like them, even some of those that's broke them.
They give you ratios that allow you to stay on the power more, overcoming the big gaps between third and fourth in some four speed boxes and stop you chasing it. The overall final ratios in top gear are not that much different so it's not like you gain any overall speed advantage from the extra gear, you just get there nicer.
I think you'd need to weigh up whether you could justify the cost against the perceived benefits.
MB 5 speed box.
Posted: Sun Dec 06, 2015 1:49 pm
by slangen
Is there also a FB link to the 2 speed Doncaster gearboxes I heard about the other night?
Re: MB 5 speed box.
Posted: Sun Dec 06, 2015 9:38 pm
by Muppet
Re: MB 5 speed box.
Posted: Sun Dec 06, 2015 11:46 pm
by joespeed
depends how you drive,if your local fast ball out rider then no a close ratio is what you need,for the fast man that does the long distance the 5 may be easier to cruise at higher speed on the motorway if it is windy or uphill then drop down into 4th at the same revs,,big difference in the cash another factor is if you have a revvy engine with a narrow power band the 5speed will be nice with correct sprockets!
Re: MB 5 speed box.
Posted: Mon Dec 07, 2015 11:00 pm
by corrado
post removed
