Page 6 of 6
Re: brass exhaust nuts
Posted: Sat Jan 10, 2015 11:45 pm
by lambro
sunrisemac wrote:I decided to put mine on the inlet manifold studs instead................
Trouble with doing that is that the nyloc on the inlet nuts melts when fitted to the exhaust.
On the plus side, if you put nylocs on the exhaust studs, you can only thread them om on the one way
Posted: Sat Jan 10, 2015 11:58 pm
by Timbo
.....put the rounded end on the stud first......that should sort it...
Posted: Sun Jan 11, 2015 12:00 am
by sunrisemac
I'm gonna put 'K' nuts on in that case with a bit of lockwire, drill them for split pins and belt the ends over once fitted , that should do it
Posted: Sun Jan 11, 2015 12:23 pm
by slangen
That's it I'm putting wing nuts on.
Posted: Sun Jan 11, 2015 1:18 pm
by coaster
slangen wrote:That's it I'm putting wing nuts on.
Ah but which way up are you going to fit them
Posted: Sun Jan 11, 2015 3:37 pm
by slangen
Wings first, it will lock them up good.
