[youtube]87ws_Krl_3I[/youtube]
http://www.youtube.com/watch?v=87ws_Krl_3I
1967 Vespa SS 180 restoration
- victor
- registered user
- Main scooter: Tv175 but currently a SS210 :)
- Contact:
Hmmmm I'm not sure C but I'll consider it. I'll also consider adding a tank and perhaps even a saddlecoaster wrote:Sounds weak Vic, get that filter on there
Then I'll pop by to say hello
- victor
- registered user
- Contact:
And that was a true forth kick! With just a tube with 5cl petrol in
Noticed that the carb was p1551ing fuel though, from the lid where the filter sits and the hose enters. Needs a new gasket, will have to pop by Neil tomorrow and see what they might have...
- coaster
- registered user
- Contact:
That would be nicevictor wrote:Hmmmm I'm not sure C but I'll consider it. I'll also consider adding a tank and perhaps even a saddlecoaster wrote:Sounds weak Vic, get that filter on thereAnd a front light.
- victor
- registered user
- Contact:
Seriously need a new carb gasket - this one is leaking by wheredowegonowbutnowhere, on Flickr
Vespa SS 180 lever screw and washers by wheredowegonowbutnowhere, on Flickr
Correct lever screw and washers for Vespa SS 180 by wheredowegonowbutnowhere, on Flickr
Invaluable tool by wheredowegonowbutnowhere, on Flickr
Vespa inner tube protection by wheredowegonowbutnowhere, on Flickr
- victor
- registered user
- Contact:
Close now...
Timing, timing, timing by wheredowegonowbutnowhere, on Flickr
More timing by wheredowegonowbutnowhere, on Flickr
Hey Coaster...
Carb and carb rubber fitted by wheredowegonowbutnowhere, on Flickr
Vespa PX engine conversion light switch by wheredowegonowbutnowhere, on Flickr
This is how the back of the SIEM SS 180 light switch should look by wheredowegonowbutnowhere, on Flickr
And now the lights are working by wheredowegonowbutnowhere, on Flickr
Front light sorted by wheredowegonowbutnowhere, on Flickr
Tank cap nut before fixing by wheredowegonowbutnowhere, on Flickr
Petrol tap lever fitted by wheredowegonowbutnowhere, on Flickr
Some problems too, first of all, there is a loose piece of metal inside my speedo:
Loose metal piece inside my speedometer by wheredowegonowbutnowhere, on Flickr
That's how it looks the loose metal piece by wheredowegonowbutnowhere, on Flickr
Then, there is some oil spitting and dripping:
Spitting oil from the cylinder head by wheredowegonowbutnowhere, on Flickr
Let's see what can be made about that tomorrow...
Hey Coaster...
- victor
- registered user
- Contact:
Many small steps...
Having fixed the leaking head (hopefully) - see separate thread - I could continue with more important, aesthetic details...
Tank fitted by wheredowegonowbutnowhere, on Flickr
Re-furbished tank handle by wheredowegonowbutnowhere, on Flickr
Saddle fitted by wheredowegonowbutnowhere, on Flickr
Comments?
Comments?
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
Looking forward to seeing it all together and polished up now.
- victor
- registered user
- Contact:
Getting there, getting there. Just some odd problems to sort such as the speedo, jetting and double checking timing with a better strobe than mine and then after the rubber is on it should be back on the streetDoom Patrol wrote:Looking forward to seeing it all together and polished up now.
