Page 5 of 5
Re: Starting after top-end rebuild and new carb
Posted: Tue Oct 02, 2018 8:46 pm
by loadedscooterist
Hi Paul, Thanks for that and I replaced the 6v system to a 12v last winter. I am going to check what flywheel i bought from the supplier.
by loadedscooterist
Will also be getting my engine guy to double check the timing when we disassemble.
Posted: Wed Oct 03, 2018 12:00 pm
by loadedscooterist
Ok, so looks like I will need to buy a new GP flywheel if I go down that route. Also Do i need to replace the stator plate as well? Sorry for the obvious question?
Posted: Wed Oct 03, 2018 2:18 pm
by HxPaul
Some stator plates have a smaller hole in the centre,some dont,if yours does then the centre needs boring out,or buy a new stator plate.
Posted: Wed Oct 03, 2018 3:20 pm
by loadedscooterist
Hi Paul, I wont know until the flywheel comes off and we can then make a call / buy new parts. Whilst I am there do I need to replace the li bearings with GP ones? Thinking about the shopping list now....
Posted: Sun Nov 25, 2018 4:51 pm
by johnny650
loadedscooterist wrote: ↑Tue Oct 02, 2018 4:15 pm
So whilst I am devastated like you about the Summer come and gone I am determined to get a few miles onto her before the bad weather!
Will report back when I have some updates.
any progress ? did you get the drive side seal replaced ? I ended up having to do mine then I found a leak on the base gasket due to the previous owner being a bit too enthusiastic with grinding the ports.
there was so little gasket surface left on the barrel I had to use a aluminium base gasket to get a seal . All done now though.
let us know how things have gone ..........or not :roll: :lol:
