Page 5 of 7
Re: TV175 1963 strip and rebuild
Posted: Fri Dec 30, 2016 12:34 pm
by Doom Patrol
fluff34567 wrote:1 thing that I do need to mention and it's important! Here you are not allowed to fit any non original or "non authority approved" parts but saying that if it looks original ...... this is in relation to cylinder kits. Crank will never be seen again so i can fit anything.
Where are you then Fluff?
Posted: Fri Dec 30, 2016 12:41 pm
by fluff34567
Switzerland, land of regulations.
Posted: Fri Dec 30, 2016 12:57 pm
by Adam_Winstone
I'd be tempted to simply buy a replacement TV crank and rebuild it back to standard as the weak taper of the TV crank does not seem to become a problem until you increase cc or performance considerably. If you fit a lighter than standard flywheel, this will also have a dramatic influence and reduce any chance of the crank's taper shearing off.
Posted: Sat Dec 31, 2016 1:59 am
by fluff34567
Hi Adam... yes that is also my initial thoughts also.. I sent a few emails and will wait for the responses.
Posted: Sat Dec 31, 2016 9:42 am
by warts
Isn't the lightened flywheel modified then?
Re: RE: Re: TV175 1963 strip and rebuild
Posted: Sat Dec 31, 2016 3:43 pm
by fluff34567
warts wrote:Isn't the lightened flywheel modified then?
It will never been seen and no one is going to take a flywheel off to check it.
Posted: Sat Dec 31, 2016 4:04 pm
by garry inglis
buzzsolomoto has a 175 crank for £120 plus postage £300 to switzerland lol lol
Posted: Sat Dec 31, 2016 4:19 pm
by Doom Patrol
Some of the German dealers have to be the best bet.
http://www.scooter-center.com/en/produc ... 5*1*1*1*16
Posted: Sat Dec 31, 2016 4:51 pm
by cgt75b
I got one from Turners Merseyside many years ago £60 still going strong!
Good luck.
Posted: Sun Jan 01, 2017 12:22 am
by storkfoot
Sadly, Turners are no more :-(
