Page 5 of 5
Re: More problems, exhaust full of petrol
Posted: Mon Sep 05, 2016 2:08 pm
by HxPaul
Is the tang bent on the float causing the fuel to flood out before the float needle seats in the float valve.Or did you forget to fit the fibre washer ?
Posted: Mon Sep 05, 2016 2:50 pm
by Snails
The tang was bent on the original float causing just that issue (possible), bent the tang back up and it made it happen less but t still happens so I replaced the float entirely
fibre washer fitted
(in fact new float valve seat as well and I double checked it).
Posted: Tue Sep 06, 2016 3:33 pm
by Snails
Been mulling this over and I have a plan!
I'm going to fit the 25 phbf carb I have and see if I get the same issue, a bit of pain in the ass but it will save me buying something I dont need and I am in no rush now as summer is nearly gone
If the bhbf works I will sack the BHBH and buy that 24mm for my Vespa.
I'll be back with an update in about 2 months once I've swapped the carbs over
