Page 5 of 20
Re: lambretta 290 rotax
Posted: Sat Dec 10, 2016 9:05 pm
by holty
drunkmunkey6969 wrote:Might be an optical illusion from the camera angle, but that con-rod looks pissed, and the big end looks real skinny.
Has the rod been altered to fit through the wider webs?
heres a couple of pics
IMG_0190_zpscjsyhsic by
stephen holt, on Flickr
Posted: Sat Dec 10, 2016 9:16 pm
by garry inglis
looks good holty
Posted: Sat Dec 10, 2016 9:24 pm
by drunkmunkey6969
Ah, I see, it's seated in a recess...that's pic shows it better. Looks good n beefy from that side.
Posted: Sat Dec 10, 2016 9:45 pm
by Muppet
width 46mm or 47.5 ?
Posted: Sat Dec 10, 2016 10:18 pm
by holty
its a big one 51mm wide
Posted: Thu Dec 22, 2016 11:09 am
by holty
not much progress, just waiting for my case to come back from more welding, but my mag spacer, circlip and seal has arrived
IMG_0245_zpsg6hobc4j by
Posted: Thu Dec 22, 2016 4:57 pm
by garry inglis
hi holty how have you worked out the packer size 0.5 either side of crank plus 51mm
Posted: Fri Dec 23, 2016 12:15 pm
by Rich_T
Your base gasket area is already machined, so I'm guessing the mag packer is 5-ish mm and you intend to machine 5mm into the casing on the drive side? Are you doing away with the seal plate and going for fuel lubed drive side?
Posted: Fri Dec 23, 2016 6:43 pm
by Knowledge
Rich,
While we await the proper answer to your question, could the drive-side seal plate be retained if the whole centre-line of the crank was shifted over towards the mag-side?
Surely this would be possible if the barrel spigot was re-manufactured, which is pretty much what you have got in Holty's engine.
Still, whether that was thought of before this crank was commissioned........
Come on Holty. Give us the answer.
Posted: Fri Dec 23, 2016 7:15 pm
by holty
the centerline is the same as a standard engine, so 5mm is machined from the inside of the crancase on the drive side, its the corner where the seal plate fits, except i wont have room for one, im using a vespa clutchside crank bearing , followed by the thin circlip, followed by the seal, then the mag spacer should give me enough space on the flywheel side,a bit of work to do, but my casing isnt back get so i cant get on with it yet, will post some pics when ive made some more progress.
