Page 5 of 7
Re: Horrendous scraping when kicking over
Posted: Sun Jul 13, 2014 10:01 am
by shocky
Are those bits alloy or steel they look alloy
Posted: Sun Jul 13, 2014 11:05 am
by vRSG60
They don't feel soft enough for alloy.
Posted: Sun Jul 13, 2014 11:29 am
by Jazzy
Piston skirt.debris jamming the crank.
Don't force it or you could break the crank housing.
Posted: Sun Jul 13, 2014 1:26 pm
by rosscla
Assuming he'd have said if the piston was damaged in any way when you took the barrel off.
Looking like crank big end
Posted: Sun Jul 13, 2014 4:30 pm
by Jazzy
First rule of this game is Asume nothing.
First time I lost part of the piston skirt the break was so clean it was hard to tell anything had fallen off.
Posted: Sun Jul 13, 2014 5:36 pm
by vRSG60
Looking like big end. The only but I'm going to struggle to do myself, take the crank off
Posted: Sun Jul 13, 2014 5:41 pm
by bazza3004
If you have stipped it as you state so far im sure you wont have much trouble taking the crank out.
Posted: Sun Jul 13, 2014 6:16 pm
by vRSG60
Well big end bearings gone definitely I can move the con rod about 10mm at the big end. Bugger and damn.
It looks like I need special tools for the crank. May as well take the engine out and take it somewhere to be done.
Posted: Sun Jul 13, 2014 6:55 pm
by coaster
vRSG60 wrote:Well big end bearings gone definitely I can move the con rod about 10mm at the big end. Bugger and damn.
It'll be a bit easier with special tools but it's perfectly possible to remove and replace the crank with normal hand tools. I know as I don't have any 'crank' tools myself and have never had any problem. Just don't use a hammer directly on the drive side to knock the crank out if you want to use the webs again.
Posted: Sun Jul 13, 2014 8:52 pm
by vRSG60
I'm assuming it'd be better to replace the whole crankshaft and not just the big end bearing?
