Page 5 of 10
Re: Fans /airflow / techies wanted
Posted: Sat May 16, 2009 1:20 am
by Andy Pickering
I wish this was a video call youd p155 yourselfs guys Im working this out...hand flowing up and be drawn in at speed to give the venturi effect.(much as a vacuum effect being sucked in)..
Posted: Sat May 16, 2009 1:24 am
by RICSPEED
i guess ill need to draw it
Posted: Sat May 16, 2009 1:26 am
by Andy Pickering
YES YES get it now....When I was a kid my mum would make the coal fire every morning..before lighting it she would cover the front with news paper..then light the under grate...now the air was stuck so had to go somewhere..and it would rush up the chimney...now your plan sean would be for this air to rush out over the cylinder..?
Posted: Sat May 16, 2009 1:27 am
by Andy Pickering
RICSPEED wrote:i guess ill need to draw it
Got drawings at work ric...but I was sober then.....
Posted: Sat May 16, 2009 1:31 am
by RICSPEED
Lam46 wrote:YES YES get it now....When I was a kid my mum would make the coal fire every morning..before lighting it she would cover the front with news paper..then light the under grate...now the air was stuck so had to go somewhere..and it would rush up the chimney...now your plan sean would be for this air to rush out over the cylinder..?
thats it
Posted: Sat May 16, 2009 1:36 am
by Andy Pickering
So you could duct and vent into the top of the frame thus forcing cold air over the engine stroke cylinder then it would by simple pyhsics force the hot air underneath or road bound...
Posted: Sat May 16, 2009 1:43 am
by sean brady scooters
its the fact that a chimey is up high............in the passing wind that makes it work....................
the wind..........from any direction..........causes a suction on the chimney spout and helps draw away the smoke...............heat etc............
it also helps it draw/which in the case of old coal fires.........means that if its windy............the suction will create draw.........which means that it will suck in more air into the fire,which will then burn faster..............and create even more energy..............
when starting a coal fire............the old trick of covering the aperture with newspaper etc..................just basically enhanced the venturi effect..................
Posted: Sat May 16, 2009 1:44 am
by RICSPEED
Posted: Sat May 16, 2009 1:47 am
by RICSPEED
sean brady scooters wrote:its the fact that a chimey is up high............in the passing wind that makes it work....................
i wont bring up steam engines /blowers/blast pipes
Posted: Sat May 16, 2009 1:54 am
by Andy Pickering
Bailing out guys...been good though..apart from I always get paid for this sort of thing....
