Page 5 of 5
Re: TS1 top end setup advice needed
Posted: Thu Feb 14, 2013 9:14 pm
by sean brady scooters
hope your gonna take this valantines eve off with your missis and stop messing about with your moped :D
Posted: Thu Feb 14, 2013 9:49 pm
by Yanker
He said his Missus is in Saudi Arabia (with some di***y A***b) let him get mucky with his moped in peace/living room/bedroom/greenhouse ffs
Posted: Thu Feb 14, 2013 10:03 pm
by coaster
Yanker wrote:He said his Missus is in Saudi Arabia (with some di***y A***b) let him get mucky with his moped in peace/living room/bedroom/greenhouse ffs
Had to settle for an exchange of 'electronic' V day cards, she's not back until next Wednseday. My real problem is I need to at least LOOK as if I've been doing some diy on the house :oops:
Posted: Thu Feb 14, 2013 10:55 pm
by rosscla
This one?
Posted: Fri Feb 15, 2013 10:08 am
by Darrell Taylor
coaster wrote:Right, barrel's off again, I messed about with the vernier and eventually got figures in the range that Darreel quoted above. Very difficult to be completely consistent though as from the top ot bottom of the barrel you are not looking squarely at the roof of the port. Anyway, I just fed the figutres into Eden's calculator and it gave 176.5 exhaust and 124.7 transfers. Then I spotted the bit about deducting the squish so with 1mm removed from both measurements it comes out at 129 and 180 (I had already entered the piston to crown hight as zero.....what do you think?
Spent the rest of the day fettling the new gear selector to get it to work, had to grind loads off to stop it fouling on the case :?
easier to put 0 in the calculator and deduct off your measurement
If u got 33.2 ex and deduct 1.2 sq(piston 1.2 below tdc) = 32 183.5
45.9 tr and deduct 1.2 sq = 44.7 128.72
so 27.39 blowdown
if u remove a base and add a head gasket (?0.7mm swap) youll have basically how a ts1 is set up,
with a 0.7 head gasket piston sat 0.5 below tdc giving 1.2 sq
thats 33.2 - piston 0.5 below = 32.7 = 180.76
45.9 - piston 0.5 below = 45.4 = 125.21
so 27.77 blowdown
so the lowered cylinder has a higher blowdown effectively tuning it but without the side effect of raising the ex port and bringing it onto pipe higher up the rev range
have ur cake and eat it :)
Posted: Sat Feb 16, 2013 11:30 pm
by Yanker
Check your contents insurance is current, slop some dulux on your worst carpet/floor covering, break a step on your ladder, wrap right hand in gauze and safety pin (importantly if you are left handed then reverse), sit back and enjoy all the pleasures of a hero's return gifts etc. without the ball-ache?
Posted: Sun Feb 17, 2013 12:18 am
by coaster
She freely admits to being a bit gullible but I somehow think she would see through that rouse....like the way you think though mate :fb:
