Page 5 of 5
Re: sip speedo working with wassel
Posted: Sat Feb 16, 2013 10:55 am
by Minority
victor wrote:So seven pages on, some of you must have fitted it to a Tv/SX type headset. Have you noticed the same issue as described by Sticky in Scootering..?
Really want one, not only for the temp gauge but also for the second mph indicator as my Tv is European with km/h speedo
I 've fitted one to mine and I
did have clearance problems, even without using the speedo cable (using the electronic sensor).
I still think it's worth fitting, just don't expect it to be "plug & play" as it were.
Not quite sure what you mean by the "second MPH indicator". There is only
one speed indicator, it's digital and can be either MPH or KPH but is
not changeable on the move.
Posted: Sat Feb 16, 2013 11:55 am
by Wolf
soulsurfer wrote:Is there there any way of telling whether you have the latest version (with low fuel indicator) from the packaging prior to fitting?
just had a look at my packaging , it does not mention the low fuel indicator. but as eden says it is in the user manual.
Posted: Sat Feb 16, 2013 12:08 pm
by victor
Minority wrote:victor wrote:So seven pages on, some of you must have fitted it to a Tv/SX type headset. Have you noticed the same issue as described by Sticky in Scootering..?
Thanks for the input.
As in regard to the second indicator, if I look at your image I can see the manual speed indicator as well as a second digital one that reads 0 km/h. Not sure if I've misunderstood something though....
Posted: Sat Feb 16, 2013 12:12 pm
by sideout
This is my mk2 SIP fitted to an SX headset using cable drive. No fitting issues at all for me
Posted: Sat Feb 16, 2013 1:27 pm
by victor
Eden wrote:
Victor, the needle dial reads RPM on these speedos
Thanks for the info Eden - I thought that was customisable, either or...
Still getting one though, what I need is the temp reading
Posted: Sat Feb 16, 2013 1:29 pm
by tonydevon
read these threads and scared stiff about getting one to work on my scooter, but just discovered that the speedo on the gp project I bought has no needle
oh dear need a new speedo, hmm shiney digital one
Posted: Sat Feb 16, 2013 2:14 pm
by Minority
Lucky you! Nice to know they fit in some SX headsets. Is yours chrome ring/non chrome ring? and maybe yours is a genuine innocenti, I've no idea wahat mine is
(Like that colour blue by the way)
Posted: Sat Feb 16, 2013 2:16 pm
by Minority
tonydevon wrote:read these threads and scared stiff about getting one to work on my scooter, but just discovered that the speedo on the gp project I bought has no needle
Go for it! With a GP you shouldn't have any fitment issues, and any other little issues (like running a resistor type plug) can easily be resolved.
Posted: Tue Jun 23, 2015 11:17 pm
by eden
sideout wrote:As a matter of interest Eden, why did you decide to use the magnetic pick up and not the speedo cable drive?
ive just been out on my scooter with the sip speedo running off the cable with the setting set at .77 like it says in the manual... it reads higher than the gamma speedo. what settings are people entering for the scootrs anti dive front brake speedo drive?
Posted: Tue Jun 23, 2015 11:38 pm
by Grumpy225
eden wrote:sideout wrote:As a matter of interest Eden, why did you decide to use the magnetic pick up and not the speedo cable drive?
Interesting, mine reads about 3mph fast also (against my gps). Using the same .77 on a standard italian dl hub
