Special X wrote:Camlams recomended jetting for 186/200 Mugello with an ancillotti and PHBH 30mm
45 slide (OK)
X2 needle (way too rich for an AV atomiser X7 would be better)
AV266
105 Main (wrrrrrrrrrrrrrrrbang) needs a 120 ish
53 idle
50 starter
This is where we are going to disagree a bit
It's exactly what i'm talking about. Carb jetting is not as "matter of fact" as you seem to think.
I agree in the fact that if you were using an X7 needle and AV266 atomiser or X13 and AV264 the main jet would need to be increased, however if you are using a richer atomiser/needle setting the main can be dropped, sometimes significantly and that is fact!
If you dont believe me get an EGT and try it. Put in an X2 and AV266 and 120 main jet and
it will be rich all the way up to full throttle. Keep the X2 and AV266 and come down slowly( (and safely) on the main and you will find the spluttering goes away and you have a much cooler mid range and your main 3/4 to full throttle setting will be cool enough too!
However..DO NOT TRY THIS WTHOUT EGT or DYNO or some other fast, accurate reading.
A real classic example of this, is AF Rayspeed used to recomend TS1's running a 30mm delly to use an AV266/X7 with a 140-155 main jet.....
You
would need a main jet that size if your running an AV266/X7 but it
will be still lean in the mid.
Well, some may just about get away with this if they spend their time at full throttle but for the majority it's gonna be way too lean in the mid range!
Most dyno's, tuners will end up with something close to AV268 or AV266 with X2 and a 130 or 135 main jet! (see the BIG difference in mains used because of the richer mid range).
Another example is my 225 Monza. If i put in an AV266/X7 i can run up to a 155 main and it will still pull well! But my EGT is telling me that my mid range is so lean i'm gonna go pop if i hold it there for 10 miles or so.]
If i put in an AV268 and X2 it will not run at full throttle with a 155 in (way too rich), and i end up going down to about a 132 and the mid is still cool and so is full throttle.
The moral is that if you use a rich atomiser/needle combo you will end up running a main that is a lot smaller than if you ran a leaner atomiser/needle combo.
The main jet is important but do not sacrifice your mid range to run a larger main.
My other point about the way an exhaust hugely effects jetting is also reflected as the above setting is for an ancilotti exhaust.
For an expansion they recommend the atomiser to go to AV268 and main to go to 115.
I know for a fact that a clubman style exhaust requires a smaller main than an expansion just by looking at dyno sheets that people have posted when running clubmans compared to expansions.
