Re: Holed piston!!
Posted: Mon Apr 30, 2012 11:28 am
I'm not sure that there is a debate to be had here? What we seem to be saying, perhaps even agreeing on , is that dynos serve as a very useful tool for setting up motors but that they are only as good as their operator. Unless a motor is being built for the track, there should always be a safety margin designed in to the final setup, otherwise an air leak, exhaust coming loose or change of fuel will cause a motor to have problems. Setting a motor to be 'on the button' leaves no safety margin and puts the motor and rider at risk.
However, this thread was started to discuss poor fuel issues and, as someone who has suffered from this, do think that the problem with fuel needs to be acknowledged. My experience with poor fuel, which some of you may have seen me post before, was coming back from Euro Netherlands. I'd ridden there with the Cambridge Lambretta boys and my bike had been without issue, was set very safe and was a pretty much standard GP200 motor. However, we al filled up just before getting on the ferry for the return voyage, with me filling up at the pump available, which I think happened to be super unleaded. I was the only one of our travelling group to use this pump. Onto the ferry at walking pace, then off the other side, with the rest of my group heading north and me heading west to get onto the M25. However, when getting onto the first fast road from the port, I realised that the bike was not running as usual and that it gave all the signs of running very hot. I pulled over immediately and changed my plug grade and went bigger on my pilot and MUCH bigger on my main jet. The bike was still not right but it felt like I might be able to nurse it further. Not long after this I pulled into a layby that had a couple of Lambrettas pulled up so that I could see if I could help, only to hear that they had filled up at the same station and were having problems with bikes that had been running fine until then. What really compounded that the fuel was the cause of the problems was that a bloke walked over to ask us what was wrong as he was waiting to have his new family/works car recovered as he had filled up at the same station and suddenly had all of his engine management warning lights come on and instruct him to stop using the car and phone for recovery! Sadly, at least one of the 2 Lambies was beyond further use, probably with a holed piston, and was going to need recovery too. With nothing that I could do to help, I limped on until the next fuel stop and quietly dumped my fuel (safe in the knowledge that petrol stations have fuel/oil interceptors to cope) and then refilled with new fuel. 50 yards after pulling out of the petrol station I had to pull over again as the bike was un-ride able, with it being so rich on the revised set-up so I put back in the original jetting and the bike was immediately back to its usual self, which I held flat out (standard 200 motor) for the remaining trip around the M25 and up the M40, with the motor not missing a beat.
Without a shadow of a doubt, these issues were 100% related to fuel.
Another pal phoned me for help with a very reliable bike that would suddenly would not start or run. First question was, “What’s changed? Fuel?â€, to which he said not. He then went to see a dealer, who sold him a new crank, bearings, seals, mag housing and gaskets, only for him to rebuild it all and find that it was exactly the same! He badgered me into saying that I’d look at it so he paid to hire a van and bring the bike to mine. Before lifting a spanner I asked him to talk me through it all again, however, the story changed this time to say that he had indeed just put fresh fuel in from his local (big brand) petrol station. As such, he knew that the fuel was fresh so had discounted this as a possible problem. As the bike had a spark and the plug was wet, it should have been at least trying to fire. I drained the tank and emptied the bowl, replacing it with fuel drained from one of my bikes that had not moved for quite some time. Immediately the bike fired and after smoking like mad for a minute, whilst burning off the crap that had made its way into the exhaust, the bike ran perfectly and all was resolved, other than the fact that the owner then decided to strip the motor back down to take out the un-shimmed crank that the dealer had sold him and to put back in the original shimmed race crank. This folly cost the owner hundreds of pounds, many hours of travel and working on the bike, and the use of the bike for between 2 weeks and a month, all because of sh!t fuel from a big named outlet!
Bad fuel is out there and will wreck engines, however, it often gets blamed as an easy get out for people looking for a factor to blame. As such, it is probably a factor in only a few of the cases for which it is blamed. However, in this case I think that it is a very likely cause as it does seem unlikely that 2 bikes would suffer the same fate so soon after filling up.
Regarding my exhaust width comments, yes, the kit that has increased its exhaust width has also had to revise its piston rings from 1.5mm to 1.0mm as the rings couldn’t cope with the wider exhaust… indeed, I know of one of the early wide exhaust versions being sent out with a 1.5mm ring piston, which lasted no time before dropping a ring. Luckily for the owner, the bore plating was not damaged and the port edges just needed cleaning up a little. This sort of failure does not make me think that the porting is right for road use, just that the designer is relying on ring quality to try to cope with what I see as a design flaw! If the motor can’t cope with the quality of rings, at 1.5mm, that have been standard in high performance Jap motors for years then I think they’ve taken it too far. Also, the squaring off wear damage that shows on over-wide exhaust ports suggests that a well-shaped (but too wide) exhaust port will eventually suffer wear and ring breakage, regardless of shape and ring quality allowing all to be well to begin with. IMO motors like this are best left on the dyno or track but are not well suited to long-term road use.
