Page 5 of 16
Re: Tubeless rims in the UK?
Posted: Mon Mar 14, 2011 3:19 pm
by RICSPEED
corrado wrote:
A Saigon Scooter Centre billet Pepperpot style won't fit, it may fit if you turn down the outer edge on the billet but that's not something I'd do or recommend..
any chance of a pic to show what the problem is??
Posted: Mon Mar 14, 2011 3:23 pm
by Ian Hepworth
Just to clarify about whether my Spanish hub has been filed or not.
I showed it to Mark Broadhurst today and he confirmed any marks looking like filing on it are from the factory.
Posted: Mon Mar 14, 2011 4:40 pm
by corrado
No.
Posted: Mon Mar 14, 2011 4:44 pm
by soulsurfer
Ian Hepworth wrote:Just to clarify about whether my Spanish hub has been filed or not.
It seemed to fit the Spanish hub on my bike okay, but not so with this one, some filing or Dremel work is required, but no biggie, it may just be the powdercoat thickness.
For those that want to see, here's some more pics, the alloy finish is clear lacquered...
This one's a bit close to the caliper for my liking, it's an MMW/Worb5 hub with 220mm disc, the 200mm disc is fine.
It's a shame they forgot to fit a valve to this one though, but is shows the valve seating area
They're closed today, so I shall call AF tomorrow, but the question is should I accept a replacement valve and fit it myself or request a new wheel with valve fitted???
Posted: Mon Mar 14, 2011 5:22 pm
by Bilko
Thanks for sharing the pics Mike. They look superb.
Posted: Mon Mar 14, 2011 5:53 pm
by RICSPEED
soulsurfer wrote:
so ....its the back edge of the lugs clearing the rim thats the issue then?
Posted: Mon Mar 14, 2011 6:02 pm
by Andy Pickering
They look a cracking bit of kit..well we should have some road test results soon then..Soulsurfer/Rube.
Posted: Mon Mar 14, 2011 11:08 pm
by wack 63
Received mine today and checked to see how they fitted on an Innocenti rear hub and was surprised that the rim doesn't sit nicely on the hub like a good set of rims would as there is a gap of a few mm .So it appears to me that all the force will be on the studs as these along with the shoulder on the nuts are the only things that centralise the rim.I also tried one on a PM billet front hub and it has the same problem although the centre spinners "back" does sit in the rim with only a small amount of play. Not very wide either so can't imagine 100/90's fitting as it says on the box to use 350's.Hmmm
Posted: Tue Mar 15, 2011 1:02 am
by corrado
That's the same problem that you'll have with the Saigon billet disc brake, but with that picture it may be possible to file or dremmel a bit off the hub but on the Saigon billet it fouls all the way round, a chamfer on the billet hub might work but it's not something that I'd risk doing.
Posted: Tue Mar 15, 2011 1:30 am
by RICSPEED
wack 63 wrote:Received mine today and checked to see how they fitted on an Innocenti rear hub and was surprised that the rim doesn't sit nicely on the hub like a good set of rims would as there is a gap of a few mm .So it appears to me that all the force will be on the studs as these along with the shoulder on the nuts are the only things that centralise the rim.I also tried one on a PM billet front hub and it has the same problem although the centre spinners "back" does sit in the rim with only a small amount of play. Not very wide either so can't imagine 100/90's fitting as it says on the box to use 350's.Hmmm
that was the same problem with the wide steel ones
