Page 5 of 6
Re: OK, thinking caps on please......
Posted: Fri Jul 09, 2010 5:17 pm
by Stokie
Booby wrote:Think he would be better off with some weed rather than oil
All donations accepted
Posted: Fri Jul 09, 2010 5:29 pm
by camel
are you experiencing a "wet" plug situation where as the spark tracks down the most direct route when the pug is in the head,but seams to spark normally in your hand?ive had this on a similar spec ts1,changing the plug would cure the problem for about 20 miles then re-occur
Posted: Fri Jul 09, 2010 6:33 pm
by slidingdog
STATOR PLATE! most probably the black box/pick up
have repaired a couple ,last one going to beatsugar, the stator had come loose wearing the black box/pick up,it would run fine untill stopped, then wouldn't spark, but all readings were fine with multimeter
Posted: Fri Jul 09, 2010 6:40 pm
by Andy Pickering
drunkmunkey6969 wrote:there's a bottle of oil in it for you if you're right
Make it a bottle of Strongbow and ill come on Rics bmx to have a look for ye Dan...
Posted: Fri Jul 09, 2010 8:51 pm
by RICSPEED
Lam46 wrote:drunkmunkey6969 wrote:there's a bottle of oil in it for you if you're right
Ill rent you it
Posted: Fri Jul 09, 2010 10:42 pm
by corrado
corrado wrote:Got a mate with very similar problem, seems to go 2 to 3 miles then just stop dead as if electrical. Fires up again after 2 or 3 minutes without changing anything, then runs for another 2 to 3 miles before stopping again. He tried a new CDI yesterday and it got him home about 8 miles without cutting out. I'll report back later if it's run ok today.
So far all the problems have gone now he's fitted the new CDI.
Posted: Sat Jul 10, 2010 9:31 am
by Timbo
Well i read it as a simple fun question, not a dealer trying to get free help FFS. A mate last week in France had a similar problem. Changed all the electrics and then found the reed valves (i have no idea what they are or what they do
)had disintergrated and the small screws had come out.........Before the weekend i would have said it was the stater plate as i had similar symptons on the way too lincoln last year.
Posted: Sat Jul 10, 2010 6:00 pm
by dirtyhandslopez
I don't see any problem with asking help to diagnose here. We are in the Lambretta tech section, no?
Posted: Mon Jul 12, 2010 12:08 pm
by J1MS
And..... The winner was ???????
Suspense is killin' me now...
Posted: Mon Jul 12, 2010 12:59 pm
by Stokie
dirtyhandslopez wrote:I don't see any problem with asking help to diagnose here. We are in the Lambretta tech section, no?
Stokie wrote:
Nowt wrong asking for help ......
