BGM Stator Failures
J1MS
A little high strength stud lock helps to keep them in place with the help of a little epoxy resin over the head of the screw onto the back plate.
I prefer the self tapper to the earlier threaded bolt.
LeeLee
After much piddling about with carb jettings it turns out the that problem was with my Stator... A BGM Stator.... Been in use since Kelso 2010.... till last weekend.. and only done around 400 miles....
I have fitted my 'Self repaired' Indian stator back on... and all is fine...!
I will contact the dealership that supplied it to see if they will send me another OR.....
PHILIPP...... Do you want me to send it direct to you instead so you can test it / repair it / send me another one...? I'll send ya a PM... :)
