Re: dans new crank
Posted: Tue Feb 17, 2009 11:41 am
Hi Sean,
........I notice that you are along similar lines with your crank shape to the old sixties Villiers one....which by the way apparently was notoriously weak and had twisting problems when handling any extra power....but as Dan says see what happens....don`t know if you don`t try?....
I thought this may be of help....but if not never mind....at least you may be re-united with that Castrol R smell!....
quote....
"Both authors use Castrol R40 or Morris MLR40 at a ratio of 25:1 as a lubricant, not because they are traditionalists, but because it is the only oil they have found to cope with the rigours of racing a heavily tuned 197 or 250. They work well, even promoting the well being of a big end bearing that can have up to 2 thou wear, with no problems. The authors have seen other riders use synthetic oils at 40:1 with unsatisfactory results. Use of synthetic oils in modern liquid cooled motors is recommended, but not, please, in 30 year old motors."
As you have now decreased your primary compression, have you had thoughts about a more "ramming effect " from a more correctly designed inlet tract....or is space limiting?....and as now the transfers are more a storing space for the fuel, do you think the design of exhaust will be able to overcome that loss of compression?....
quote....
