Re: MB Digital speedo
Posted: Tue Feb 09, 2010 11:38 pm
looks like ill be going back to grip filling a fiat strada dash to my series 1 headset then
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
phil also said I could part ex my trail tech and that ian could deliever it, now that's service.Ian Hepworth wrote:I was there when you phoned. Phil didn't say "jump the queue" - it sounded more like something like "those bloody two"..6LDA 28B wrote:Nice Phil at Mb took my order for the new digital speedo and i was sure he said (under his breath) that i could jump the queue
Now just have to get cezeta to buy my trail tech vapor
question for Mb's technical guy, Ian![]()
when can you adapt one of these for a lambretta
http://www.trailtechproducts.co.uk/acat ... _Kits.html
yes i fitted a similar one to kylies vespa, they are good quality kits, ive become shed adverse untill springtime though.....its my soft slender southern hands, they struggle with the cold.Ian Hepworth wrote:It's easy on a series 1/2 - the existing hole is round so you need to find speedo that does what you want that is smaller then you just need to knock up a ring with the OD same as the standard speedo and the ID the same as the new one. Simples.
There's a nice koso one with two temp gauges, digi speedo, rev counter etc.
They are just having the artwork done at the moment, so it should be within the month.sydduckett wrote:When does the Dactec one come out? also can you run the magnet pick up off the front wheel instead of using the standard cable? Seems a bit pointless getting a digital speedo then plumbing it into 50 year old tech..![]()
Sef
So we have 2 digital speedos coming to market at the same time...DJB wrote:They are just having the artwork done at the moment, so it should be within the month.sydduckett wrote:When does the Dactec one come out? also can you run the magnet pick up off the front wheel instead of using the standard cable? Seems a bit pointless getting a digital speedo then plumbing it into 50 year old tech..![]()
Sef
It can be run from a magnet pick up aswell.
sydduckett wrote:So we have 2 digital speedos coming to market at the same time...DJB wrote:They are just having the artwork done at the moment, so it should be within the month.sydduckett wrote:When does the Dactec one come out? also can you run the magnet pick up off the front wheel instead of using the standard cable? Seems a bit pointless getting a digital speedo then plumbing it into 50 year old tech..![]()
Sef
It can be run from a magnet pick up aswell.Will be interesting to see how they compare to each other... The Dac would appear to have the edge as far as functionality is concerned what with having the temp gauge, which i think is a big tick for a lot scooterists..Both appear to be made to fit into the series 3 aputure without any felting and both can run off a magnetic pick up.
Any more info on the Dac and what the kit is likely to come with, temp sensor, fuel sensor and so on?
Ta
sef
