MB Digital speedo
cezeta
looks like ill be going back to grip filling a fiat strada dash to my series 1 headset then :roll:
Ian Hepworth
It's easy on a series 1/2 - the existing hole is round so you need to find speedo that does what you want that is smaller then you just need to knock up a ring with the OD same as the standard speedo and the ID the same as the new one. Simples.
There's a nice koso one with two temp gauges, digi speedo, rev counter etc.
Train Driver
Ian Hepworth wrote:
6LDA 28B wrote:Nice Phil at Mb took my order for the new digital speedo and i was sure he said (under his breath) that i could jump the queue :lol:
Now just have to get cezeta to buy my trail tech vapor
question for Mb's technical guy, Ian :ugeek:
when can you adapt one of these for a lambretta
http://www.trailtechproducts.co.uk/acat ... _Kits.html
I was there when you phoned. Phil didn't say "jump the queue" - it sounded more like something like "those bloody two"..
phil also said I could part ex my trail tech and that ian could deliever it, now that's service. :lol:
cezeta
Ian Hepworth wrote:It's easy on a series 1/2 - the existing hole is round so you need to find speedo that does what you want that is smaller then you just need to knock up a ring with the OD same as the standard speedo and the ID the same as the new one. Simples.
yes i fitted a similar one to kylies vespa, they are good quality kits, ive become shed adverse untill springtime though.....its my soft slender southern hands, they struggle with the cold.
Train Driver
The sausage king Supereibar said he has never seen sausages as big as your fingers,
more like your pilsbury dough boy body :lol: keeping you in the warm house
sydduckett
When does the Dactec one come out? also can you run the magnet pick up off the front wheel instead of using the standard cable? Seems a bit pointless getting a digital speedo then plumbing it into 50 year old tech.. :?
Sef
DJB
sydduckett wrote:When does the Dactec one come out? also can you run the magnet pick up off the front wheel instead of using the standard cable? Seems a bit pointless getting a digital speedo then plumbing it into 50 year old tech.. :?
Sef
They are just having the artwork done at the moment, so it should be within the month.
It can be run from a magnet pick up aswell.
sydduckett
Sef
So we have 2 digital speedos coming to market at the same time... :D Will be intresting to see how they compare to each other... The Dac would appear to have the edge as far as functionality is concerned what with having the temp guage, which i think is a big tick for a lot scooterists..Both appear to be made to fit into the series 3 apauture without any fettling and both can run off a magnetic pick up.
Any more info on the Dac and what the kit is likley to come with, temp sensor, fuel sensor and so on?
Ta
sef
Train Driver
sydduckett wrote:
Sef
So we have 2 digital speedos coming to market at the same time... :D Will be interesting to see how they compare to each other... The Dac would appear to have the edge as far as functionality is concerned what with having the temp gauge, which i think is a big tick for a lot scooterists..Both appear to be made to fit into the series 3 aputure without any felting and both can run off a magnetic pick up.
Any more info on the Dac and what the kit is likely to come with, temp sensor, fuel sensor and so on?
Ta
sef
Both may fit the series three head set but the Mb Digital speedo will be a far superior product
:bouncing: :lol: :bouncing:
Spill the beans, have you seen and used both? What are the pros and cons of each? I'd like to know more about the egt on the DAC one.
    Users browsing this forum: Baidu [Spider] and 24 guests
