Page 4 of 6
Re: hydraulic rear drum brake
Posted: Fri Jan 08, 2010 10:23 am
by joee
markdicko wrote:i also will be using sand in a wall i"m building if that ok.lol.
depends...wheres the sand from?
Posted: Fri Jan 08, 2010 10:26 am
by Andy Pickering
Id swap some sand for this fecking snow right now.. :D
Posted: Wed Jan 13, 2010 2:02 pm
by madmaex08
any further news/pics yet?
Posted: Wed Jan 13, 2010 2:17 pm
by mark
no m8 ,im trying to rewire,engine swap , fit new trial stator , fit new frony end and trailer in a very little time that i can work on it (bout 5 hours a week) hopefully trial test it in late feb
Posted: Tue Feb 16, 2010 5:46 pm
by mark
master fitted just got to plum the reservoir in
the master was made for a series 3 not a series 1 ,thats why the spacers are there :oops:
Posted: Thu Feb 18, 2010 1:13 pm
by mark
routing into rear hub
Posted: Thu Feb 18, 2010 3:43 pm
by madmaex08
the master cylinder looks good, but for looks you could have used a shorter brakeline though. ;)
where do you plan to locate the reservoir? inside the frameloop? inside the toolbox? next to the horn?
Posted: Thu Feb 18, 2010 3:48 pm
by mark
that was the shortest i could use because of the hose being rigid near the ends for about 40mm , also the angles of the banjo would not allow it
Posted: Thu Feb 18, 2010 4:02 pm
by madmaex08
at the back it might be possible with a different style of banjo to get around. but that is just for looks and won´t affect braking of course. just keep going.
Posted: Thu Feb 18, 2010 4:07 pm
by mark
might but then hose would stick out at funny angles i tried loads if different banjos b4 settling for this one tbh i like the way its not in your face,lots of shapes in casing to get round as well . :)
