Page 4 of 13
Re: GP150 cylinder - Mick Abbey Tuned - Back to the old school !
Posted: Wed Aug 05, 2009 11:00 pm
by Mick Abbey
I have been doing a bit more to Dans barrel tonight and its not far of finished I have finished of putting the rest of the ports in the back of the cylinder, I must say it looks pretty impresive when you look at it with a piston in place at bdc (Iam sure that Dan will have some pics up soon when he comes over to have a look at it
) one of my biggest wories is the piston as I have done this mod using the STD piston with those big fat rings, cos the ring pegs point forward and won't foul on the rear ports I have also kept the ex port width within its tolerance to help the rings stay together also with the feed's to the new ports I have kept them as tight as posible so they are as gentle to the rings as posible, at the end of the day this is a test barrel and will be alterd if required to gain max power and reliability as we can maintain, I know that the std pistons are sh1t I didn,t have any other to use Dan is talking about using a modern piston with thiner rings my only concern is where the ring pegs are located will they foul in the ports that I have put in if so it is back to the drawing board and re locate the ports
(these things are set to try us
) I will keep you all posted with the progress of the work.
Mick.
Posted: Thu Aug 06, 2009 9:31 am
by Captain Chaos
My fave post of 2009 so far.....
I'm really looking forward to seeing the result of Mick's efforts.
Fascinating. Some people are just toooooooo clever!
Posted: Thu Aug 06, 2009 6:54 pm
by rog60
Posted: Fri Aug 07, 2009 7:14 pm
by drunkmunkey6969
Posted: Sun Aug 09, 2009 8:29 pm
by chris2470
It's all looking very tasty so far Mick.
So will you be designing and making the pipe also, to unlocks it's true potential ??
Posted: Mon Aug 10, 2009 11:34 am
by fishi
what exhaust and transfer/inlet timings will you use ????
looks good, the work. But I hope you will use some other piston !!!
fishi
Posted: Mon Aug 10, 2009 2:57 pm
by Supereibar
Posted: Mon Aug 10, 2009 9:10 pm
by Speed Demon
20hp @ 8500 on the dyno should be possible - that's the sort of figures people can manage with rotary Polini 135 Vespas and the Lammy has a less restrictive inlet.
Would be a good idea to find a better piston now though as Fishi says.
Posted: Mon Aug 10, 2009 9:14 pm
by sean brady scooters
its ok chaps.......we are well aware a better piston is required...................
Posted: Fri Aug 14, 2009 8:17 am
by red ghost
How do you think I feel,I live in Australia
Other side of the freakin' planet...
