Looking for TV190 wiseco thread
CT. wrote:Just buy an alloy one and have it cleaned up / ported. You'll be glad someday that you did.
yea but weres the fun in that :idea:
CT.
You can still have fun with an alloy cylinder ! I'm just saying that it's a bit of a shame to use the TV one itself when you could use a less hard to find item.....
I have a similar set-up on my SX150 which has a Mec TV type crank, clubman, Ts 185 piston, Harry Barlow ported alloy cylinder and a 2mm packer..... I painted the barrel black and it all looks fairly original (apart from carb) and is very smooth with a good spread of power.
My original SX cylinder is greased and up on the shelf for a one day maybe back to original rebuild... ...maybe ;)
CT. wrote:You can still have fun with an alloy cylinder ! I'm just saying that it's a bit of a shame to use the TV one itself when you could use a less hard to find item.....
ok i take your point on the cylinder thought you ment just buy a kit and bolt on
