Page 4 of 6
Re: Uber race crank
Posted: Wed Jan 07, 2009 7:14 pm
by fishi
aha,
Re: Uber race crank
Posted: Wed Jan 07, 2009 8:30 pm
by RinB
I ve not really said much on this as people are talking the right vibes here which is brill
I showed early in thread the Lamy crank with bell shape.
Well look at this Bike crank look what the big boys have done
Here they have belled the crank but not all the way and have actually designed a scoop as well.
Ive also seen crank with fan like shapes on the outside edges of crank webs.
Hard to discribe but look at a flywheel fans and superimpose that onto the crankwebs ;)
Whish I could find Blady pics :(
What would this do...... lets now real discuss :D
Smiffy
Re: Uber race crank
Posted: Wed Jan 07, 2009 9:06 pm
by Powolotti
do you have a bigger picture of this crank smiffy? I am not sure what they have done :D
"turbo" slot adding was quite popular in the RD scene but it killed many cranks as this took away lubrication from the bigend bearing (so they say)
Re: Uber race crank
by fishi
Smiffy
like this for the Piaggio Ciao Moped :
it is quite "OLSCHOOL" tuning from mid 80is !
look at the fans at the crankweb, I am looking for better photos.
Re: Uber race crank
Posted: Wed Jan 07, 2009 9:12 pm
by fishi
here better photos:
upps, a little big !
Re: Uber race crank
Posted: Wed Jan 07, 2009 9:18 pm
by RinB
Yep thats it lads
and yes Powolotti I believe big ends might have had probs
All good stuff :)
Smiffy
Re: Uber race crank
Posted: Thu Jan 08, 2009 12:59 pm
by drunkmunkey6969
Avantone wrote:How are cranks balanced in practice in the context of the rod/gudgeon pin/piston/rings etc?
This will help go with the info already posted...
Re: Uber race crank
Posted: Thu Jan 08, 2009 1:35 pm
by Diablo
Yes all very interesting. I found some twin 2 stroke cranks on the net which had similar modifications.
http://www.twostrokeshop.com/two_stroke ... ngines.htm
With regard to balancing I have been trying to balance flywheels between turning centres but I must have got the taper angles wrong because I am getting sticktion problems. I've been on the look out for some knife edge rollers for ages which I think is the most accurate way of doing flywheel and crank balancing.
Wouldn't be surpised if you were to find a crank like that being discussed in the top group four bikes.
I gather Charlie favours LPC and makes his exhausts do all the work.
The difficulty I think will be with the exhaust as anything off the shelf will always be a compromise.
Re: Uber race crank
Posted: Thu Jan 08, 2009 1:50 pm
by Avantone
Dan,
I feel like I've sat through a David Lynch movie watching those! :lol: WTF was that all about?
Video 1. Twiddles with end of conrod and put on scales repeatedly :?
Video 2. Spins crank round for no apparent reason :?
Video 3. More spinning with a object taped into the small end :?
I'm even more mystified! I would have thought proper balancing would include the Piston/Gudgeon Pin/Rings/Small End/Shims/Circlips etc, as well as the front sprocket and Flywheel................
Re: Uber race crank
Posted: Thu Jan 08, 2009 2:11 pm
by RinB
Tend to agree Tony
Unless all there doing is getting a basis crank pre balanced.
Ie when you buy a crank from a supplier will they have balance a crank with piston shims bearing etc ect. I wouldnt thought so :shock:
Like you said to do a true balance of the crank system you would really need all the items you listed.
