Page 4 of 6
Re: Mb rear bearings
Posted: Wed Jun 07, 2017 1:09 pm
by kejj
6005 double sealed bearing
Re: RE: Re: Mb rear bearings
Posted: Wed Jun 07, 2017 1:15 pm
by fluff34567
garry inglis wrote:That looks good fluff do you no who is making the actual bearing I think I heard of this last year first picture though thanks
Will take the circlip out tomorrow and check but a replacement nachi skf ina bearing should be quite cheap. And wouldn't take long to replace if not happy with the standard item. Needs heating though as it has bearing retailing compound applied.
Posted: Wed Jun 07, 2017 1:35 pm
by kejj
One question is if you bang on the bearing. Will it take the seat with it?
Skickat från min F3311 via Tapatalk
Posted: Wed Jun 07, 2017 1:41 pm
by garry inglis
Hi strummer10 I had it dynod last week at scooterotica and it finished up with 135 main 55 pilot small one without emulsion u16 on second clip dp266 atomized it pushed out 25hp and 20fbt
by fluff34567
Depends what temperature retaining compound you use and if you try smash it out or use a bearing puller. Smash then maybe, puller no.
Posted: Wed Jun 07, 2017 1:49 pm
by garry inglis
Here's the print out Dan actually got it to 26 up and 21 debt but after final jetting 25hp and 20fbt
by garry inglis
Posted: Mon Jun 12, 2017 8:12 pm
by garry inglis
How's that bearing working out fluff
Posted: Mon Jun 12, 2017 8:55 pm
by fluff34567
I'm back in the workshop in 2 or 3 days.. had to fly away so will see what comes supplied as standard. Hi from NY though
Posted: Sun Jul 09, 2017 10:43 am
by fluff34567
Forgot all about this. . Took the clip out and standard is an SKF 6005-2RSH
