Page 4 of 5
Re: Suzuki 190 set up ?
Posted: Fri Dec 30, 2016 9:10 pm
by stew
Give Chiselspeed a call , good customer service ( something some dealers could learn from) and you won't have to sell a kidney
Posted: Sat Dec 31, 2016 3:21 pm
by li150ss2011
chisel reprofiled my head to suit yamaha piston, £25
Posted: Sat Dec 31, 2016 3:26 pm
by gaz_powell
+ 1 chiselspeed for heads
Posted: Sat Jan 28, 2017 7:10 pm
by Hammerite
What sort of final drive ratio would suit a 190 conversion for a solo touring rider ?
Posted: Sat Jan 28, 2017 7:45 pm
by holty
final drive ratio is influenced by the exhaust, type of gearbox comes into play as well, as does the tune of the barrel, your weight and size, do you ride solo, is it hilly near you, i opted for 5.1/1 on mine as a guess i cant say it will do you for sure but might be a starting point, that was a pm pipe gp150 gearbox, porting work quite coservative, not run yet as the frame needs paint.
Posted: Sun Jan 29, 2017 1:02 pm
by mawso
Mine runs LI 150 16/46 with a final drive ratio 4.9. Full length TV barrel, 115mm conrod. Have run it with an MB Rev-Tour, RS44 Clubman and now a MSC Micron,porting is quite restrained but not had any trouble with flat spots or not pulling in gears. Great engine that sits comfortably with TS's in riding group.
Posted: Sun Jan 29, 2017 11:56 pm
by kejj
mawso wrote:Mine runs LI 150 16/46 with a final drive ratio 4.9. Full length TV barrel, 115mm conrod. Have run it with an MB Rev-Tour, RS44 Clubman and now a MSC Micron,porting is quite restrained but not had any trouble with flat spots or not pulling in gears. Great engine that sits comfortably with TS's in riding group.
What size packer at the cylinder foot do you use with the 115 conrod?
Posted: Sat Feb 04, 2017 6:27 pm
by mawso
2mm base packer I believe, no head gasket.
Posted: Fri Mar 31, 2017 6:23 am
by Hammerite
What squish should I be aiming for fellas ?
Posted: Sat Apr 01, 2017 4:02 pm
by holty
Hammerite wrote:What squish should I be aiming for fellas ?
Off the top of my head I set mine at 1.2 mm
