Page 4 of 4
Re: Electronic kit failed already?
Posted: Fri Sep 09, 2016 7:47 pm
by Chris in Margate
Got it. Many thanks.
Posted: Fri Sep 09, 2016 8:31 pm
by EddieStone
Well, mine has packed up again. Is this really worth the effort?
I think the pick up needs to go a bit lower but can't see how to do it. It's sitting on a thick plate that presumably has the thread for the screw in it. If I cut that out (somehow) I think it will sit too low, and there's nothing to screw the screw into
Anybody any ideas?
Posted: Fri Sep 09, 2016 8:53 pm
by Grumpy225
EddieStone wrote:Well, mine has packed up again. Is this really worth the effort?
Anybody any ideas?
Back when the AF Ducati electronic was common, we would machine the inside face of the mag flange to lower the stator plate. If there is room you could also run a thinner mag flange gasket. You won't gain a lot but it might be enough to get everything to line up just right.
MBD sells gaskets in various thicknesses.
Posted: Fri Sep 09, 2016 8:57 pm
by hendy
EddieStone wrote:It's worse than electrics. It's electro-magnetics!
You have to admit, getting a several thousand volt spark out of a small engine is a miracle of determination over logic. Never mind several thousand per minute.
Volts per minute isn't a useful measurement except if you're interested in rate of rise and its impact on emi.
Joules per second (or power) is a much more useful metric. And the ignition system delivers approximately half of f@@k all horsepower.
There are 2 reasons I say this: firstly I feel like being a smart arse and secondly I'm half pissed and bored.
Posted: Fri Sep 09, 2016 9:10 pm
by EddieStone
I meant it generates several thousand volts, several thousand times a minute.
But don't let me stop you showing off!
Posted: Fri Sep 09, 2016 9:20 pm
by Muppet
EddieStone wrote:I meant it generates several thousand volts, several thousand times a minute.
i was told a cdi does the high voltage gizmothingymdoodle bit; flyweel n stuff in their dont do much after 45 volty bits
Posted: Fri Sep 09, 2016 9:21 pm
by Muppet
just sayin'
Posted: Sat Sep 10, 2016 5:16 pm
by EddieStone
Another day spent kneeling beside the blooming thing. :roll:
Cut the thick plate off the stator under the pickup, having tapped down into the laminates using an M5 tap. Pickup then needed raising by a washer thickness. Seems to be running OK now, in fact it runs very well. Looking forward to seeing if it will beat it's current record of running for two days.
Posted: Sat Sep 10, 2016 9:01 pm
by Adam_Winstone
^... sounds like you're getting there :)
Fingers crossed for day two.
Posted: Sun Sep 11, 2016 11:53 pm
by EddieStone
Adam_Winstone wrote:^... sounds like you're getting there :)
Please keep them crossed! I ran it for about 4 hours today, off to the beach and along a few A roads. Starts faultlessly and runs well. Bit stuttery around 1/4 throttle, so I've concluded that it's rich at low revs and (after a plug chop) a bit lean at high revs. Tried the choke test for high revs and it wasn't happy so maybe a small increase in main jet, and a slight decrease in pilot should sort it.
Nearly there.
