Page 4 of 7
Re: New project.
Posted: Tue May 17, 2016 9:14 pm
by 10 inch Terror
Rs fruitbat wrote:At this rate it'll soon be finished
good work mate
It shouldn't take long as I'm doing 99% of the work myself, so I'm not reliant on others. I've shipped out the frame, side panels and legshields to be blasted, as they wont fit in my blast cabinet. Everything else I can do myself though. I'm hoping to have it all complete in another 3 to 4 weeks.
T5-190 wrote:Very nice work indeed. I like the headset repair, chemical repair is under rated. We glue F1 car parts together, a lot stronger than weld in that situation. Keep the pictures coming.
I'm very pleased with the repair. It's really strong and you can't tell it's been repaired. It was worth doing, as it's an Italian one, so it's a nice fit. I'm hoping to do a bit more painting tomorrow. I'll keep you all updated. Cheers Pete.
Re: New project.
Posted: Fri May 20, 2016 12:26 pm
by 10 inch Terror
Re: New project.
Posted: Fri May 20, 2016 10:00 pm
by 10 inch Terror
Re: New project.
Posted: Wed May 25, 2016 5:11 pm
by 10 inch Terror
I've managed to get a few days in the shed, so I've started putting the motor together. The crank was an absolute pig to get the inner track bearing on, even with 3 days in the freezer, and a blow torch! Other than that it all went together smoothly.
I modified the side casing and fitted an LI ramp, rather than the end plate ramp. This is a very worthwhile modification and well worth doing. It only takes 15 minutes to do.
More pictures, as I progress.
Re: New project.
Posted: Sat Jun 04, 2016 4:28 pm
by 10 inch Terror
Re: New project.
Posted: Sat Jun 04, 2016 4:38 pm
by garry inglis
hi 10inch i think i would put a tab washer on the pull down tensioner just to make sure
Re: New project.
Posted: Sat Jun 04, 2016 5:24 pm
by 10 inch Terror
garry inglis wrote:hi 10inch i think i would put a tab washer on the pull down tensioner just to make sure
Before I close the casing up, I did remove the bottom screw and fitted a loctited stud and nyloc nut. Cheers mate.
Re: New project.
Posted: Mon Jun 06, 2016 8:52 pm
by 10 inch Terror
Re: New project.
Posted: Mon Jun 06, 2016 10:17 pm
by Rs fruitbat
I love the colour , should look sweet when all done
Re: New project.
Posted: Mon Jun 06, 2016 11:23 pm
by Padge
is it proper lechler 8016 turchese ?
bet the kids love you, looks like you broke the goal posts hanging yer parts on it !
