Re: GT240 Build
Posted: Sun May 15, 2016 9:03 pm
A bit more progress has been made, some good, some not so.
Towards the end of last week I fitted the crank bearing and seals and then fitted the crank. I'm using viton seals that came in the Taylor Tuning rebuild kit (great value and to my mind you get parts that he has vetted in circumstances that would exceed my usage), these type of seals are not something I've used before.
All the bearings and related stuff went in fine & so I fitted the crank which seemed on ok the drive side but the mag housing kind of sprung back a bit after I fitted it. After bolting everything up the crank was difficult to rotate by hand, no catching or grinding, just difficult and more so than I had expected. I left it for a day or so and kept turning it over but I wasn't happy with it. After a bit more fannying about I decided to open it up and straight away found the mag seal spring on the crank. The seal looks fine and the spring wasn't damaged at all so I put i back on the seal and gave it another test fit. No matter how gentle I was I couldn't get the mag seal over the 'hump' without rolling the spring off the seal.
I thought if I'd got that side wrong there's a good chance the drive-side was in the same situation, so thanks to James from round the corner paying me a visit today with the proper tools (and a decent hangover). We pushed off the crank & sure enough found the seal spring on the crank.
So then we put it back together. This time after every half turn of the crank puller we rotated the crank a few times, stuck the conrod locking tool back on and repeated. It felt good all the way this time. For the mag side the mag was lowered on (the seal goes over the bearing collar no problem) and James continually spun the crank while I applied a bit of pressure on the housing until there was a very positive feeling as it went down the lat 5mm, this time with no spring-back. These viton seal really are that much tighter, I really don't know how you'd do the mag side on your own.
Anyway, after doing it, messing it up, worrying about it, I was glad I took it apart & am sure it's now good. the crank rotates much easier this time, more in line with what you'd expect and feels silky smooth.
Gearbox is also in and I think I was very lucky to simply transfer the lose gears from my old series 2 in to this SIL casing with new SIL layshaft and find with the existing shim i have around 0.1mm of play. The only niggle I have is one of the spring washers has splayed, so I'll probably replace that.
BTW, Scooter Restorations asked me to send back the dodgy gear selector so hoping the refund or credit will work out fine, they've seemed good so far.
Thanks again James, disaster averted. Kickstart mechanism assembly is next for me, then probably the purchase of this months bits.
