Page 4 of 4
Re: Oil/ petrol Mix
Posted: Fri Apr 15, 2016 11:04 pm
by Jazzy
Chris in Margate wrote:The mix of 4% must by pure logic deliver more oil per engine firing cycle than 2%.
only if Bike 2 was running constantly higher revs, another variable.
Re: Oil/ petrol Mix
Posted: Fri Apr 15, 2016 11:18 pm
by Jazzy
Rs fruitbat wrote:
Jazzy wrote:Here's another variable for you,
Bike 1. 16 miles per litre at 4%
bike 2. 8 miles per litre at 2%
which is getting the most oil through the engine?
Both engines are having the same amount of oil through the engine because bike 1 is at 4% but does 16miles and bike 2 although at 2% only covers 8miles , am I correct ?
Yes on the information given.
the point I'm making is stating an oil to fuel ratio with out assessing all variables is pointless and un-scientific.
Ride, strip and examine.
Re: Oil/ petrol Mix
Posted: Sat Apr 16, 2016 1:23 pm
by Muppet
achieving 14 miles per litre on my sx150 do i need to reduce the amount of oil im using; still using my trusty brew of used mazola cooking oil blended with paraffin mixed with petrol at 2% is this too much
Re: Oil/ petrol Mix
Posted: Sat Apr 16, 2016 1:40 pm
by mick1
Regardless of the mileage a 4% mix will put more oil through the engine than a 2% mix, if it is the same amount of fuel/MPG for both bikes.
As the 4% mix is doing double the miles of the 2% then on top of the higher % it is also running for longer, therefore using more oil.
Or did you mean Bike 1 was 2% and 16 miles and bike 2 4% and 8 miles ?
Re: Oil/ petrol Mix
Posted: Sat Apr 16, 2016 10:48 pm
by Jazzy
the figures are miles/ltr the point being the difference in fuel economy having an effect on amount of oil going thru the engine.
Re: Oil/ petrol Mix
Posted: Sun Apr 17, 2016 7:46 am
by mick1
I'm going to have start reading the posts in full :oops:
So if both bikes are doing the same rev's and one is double the MPG but using half the oil %, then both are using the same amount of oil.......
The logic being the less MPG you're getting means you can reduce your oil %......
In theory if I could get another bike to do 4 Miles per litre it could run on 1% ?
Food for thought :?
