Page 4 of 20
Re: lambretta 290 rotax
Posted: Mon Dec 05, 2016 6:04 pm
by garry inglis
hi holty looking a good fit in the frame the carb must be on the right have you made a inlet manifold for the reedvalve and thanks for my engine frame holder it works great
Posted: Mon Dec 05, 2016 6:54 pm
by holty
hi garry, pleased you like the stand, the inlet that goes on the case is a part that i cut off a scrap rb20 barrel and trimmed to make it fit into a very limited space, its got a steel plate bolted to the top which i wil be welding a pipe onto for the carb to connect to, its probably going to need a cutout in the tank, something i will be tackling later, im going to collect my custom made crank on wednesday.
Posted: Mon Dec 05, 2016 8:01 pm
by garry inglis
has martin built that for you ie chiselspeed if i remember didnt mr manson make a foam template tank to fit then made a metal one
Posted: Mon Dec 05, 2016 8:56 pm
by holty
garry inglis wrote:has martin built that for you ie chiselspeed if i remember didnt mr manson make a foam template tank to fit then made a metal one
yes martin has built it from scratch, 64 stroke,larger diameter webs and wider webs, 125 rod, will post a pic when ive got it
Posted: Thu Dec 08, 2016 12:43 pm
by holty
as promised a picture of the crank that martin has made for me, i am very impressed with the quality, a work of art, martin does have a pair of these big webs on stock if anyone else wants one.
IMG_0177_zpsvktc46bl by
stephen holt, on Flickr
Posted: Thu Dec 08, 2016 2:59 pm
by garry inglis
thats a nice looking crank you wanna put it on top off the christmas tree
Posted: Fri Dec 09, 2016 2:15 pm
by holty
garry inglis wrote:thats a nice looking crank you wanna put it on top off the christmas tree
ha ha, it would need to be a strong tree, its a heavy lump, heres a couple more pics
IMG_0179_zpsimehkjsr by
IMG_0178_zpsqfqitchr by
if you look inside the web you can see the holes martin has drilled inside the webs to help balance it
Posted: Fri Dec 09, 2016 4:21 pm
by garry inglis
It is nice lovely shamfers on the webs and a decent slot on the rod for luberication off that bearing
Posted: Sat Dec 10, 2016 1:02 am
by drunkmunkey6969
Might be an optical illusion from the camera angle, but that con-rod looks pissed, and the big end looks real skinny.
Has the rod been altered to fit through the wider webs?
Posted: Sat Dec 10, 2016 10:37 am
by holty
the rod has been ground on the sides a bit, i will try and get a better picture for you, the big end isnt skinny its wider than a standard width.
