Page 4 of 7
Re: Lost piston ring peg
Posted: Sun Nov 29, 2015 10:10 pm
by Muppet
purple_pill67 wrote:skidmark wrote:purple_pill67 wrote:Did it have the gap checked/new rings after the first 1-1.5k as recommended?
I have an RT225 too.
Where did you get this info from ?
I did ask Slacker what maintenance it needed from new but its also on here about a few paragraphs down
http://www.lambrettaspares.com/info/set ... -+163.html
this paragraph? mtx piston?
"From new it's always best long term to check ring gaps as the engine is run in at around 1000 miles and replace them if worn. We always found Honda MTX pistons would wear at 1000 - 1500 miles, the bore and piston would be fine, change the rings and they would last thousands of miles afterwards. Worn rings usually show black blow past down the side of the top half of the piston below the rings. The classic symptom of worn rings is lower compression to when the engine was first built and bad starting. But as a warning we have seen rings wear so much that they have spun over the pegs and blown up at 600 miles!"
Posted: Sun Nov 29, 2015 10:24 pm
by Spursy
Mine did that this year ,,,, took it back to mb got a new kit under warranty ,,,,,, still happy with my rt too
Posted: Sun Nov 29, 2015 10:53 pm
by Spanish Fly
Am I reading this correctly?
The original rings will probably wear out within a 1000 miles but their replacements will last for many 1000's?
SF
Posted: Sun Nov 29, 2015 11:03 pm
by eden
Sounds like bollox to me.
Posted: Sun Nov 29, 2015 11:11 pm
by YAMLAM
eden wrote:Sounds like bollox to me.
i second that emotion.
Posted: Mon Nov 30, 2015 9:09 am
by dennis
Ah well,looks like another piece of expensive crap to go on the shelf.
Posted: Mon Nov 30, 2015 2:06 pm
by drunkmunkey6969
Muppet wrote:looks like an rd 350; is it?
Looks like it?
Posted: Mon Nov 30, 2015 2:33 pm
by eden
drunkmunkey6969 wrote:Muppet wrote:looks like an rd 350; is it?
Looks like it?
Details are in my Facebook photo albums
Was a standard GT that had been running for 18 months that had done close to every bsm event in that time. Not sure on exact miles covered before the peg dropped but between 6k and 8k. As I said a few posts ago, all it needed was a new piston. It didn't even need a rebore or hone
It's done a few thousand miles since.
Posted: Mon Nov 30, 2015 3:26 pm
by purple_pill67
Spanish Fly wrote:Am I reading this correctly?
SF
Wouldn't that partly be to "wear in" the barrel from the factory?
Posted: Mon Nov 30, 2015 4:08 pm
by HxPaul
I suspect that MB are talking about cast cylinders in this paragraph as they mention that it should be run in at around 1000 miles.........a plated cylinder doesn't take anywhere near 1000 miles to run in.
