Page 4 of 5
Re: Not another series 2 (update)
Posted: Sat Feb 07, 2009 8:15 pm
by simon
Posted: Sat Feb 07, 2009 8:31 pm
by joespeed
made a good job,looks well,
regards
joe
Posted: Sat Feb 07, 2009 10:33 pm
by J1MS
That look's Fantastic........
Posted: Sat Feb 07, 2009 11:02 pm
by paul-ebsc
paint the rims red............
Posted: Sat Apr 18, 2009 4:12 pm
by simon
Posted: Sat Apr 18, 2009 7:03 pm
by J1MS
Is it still running in..?? it looks very close to right but running in I like it to show a little more brown to black on the plug ....Might just try a different plug till its got more miles on it.....But if its fully run in..... leave alone it looks good..
Posted: Sun Apr 19, 2009 8:10 am
by simon
It’s only done about 40 miles, with a 3% oil mix, I was hopping the plug would have been a bit more oily when running it in
It won’t run with the standard series 2 air filter, I am running it with a homemade filter at the moment, what’s the best filter 2 get for a GP 200 engine with clubman 22mil carb
Posted: Sun Apr 19, 2009 8:30 pm
by J1MS
simon wrote:It’s only done about 40 miles, with a 3% oil mix, I was hopping the plug would have been a bit more oily when running it in
I can see in your first post... The air box its the original LI series 2 air box with the thin neck....If you can fit a GP type air box on in place of this.... It should make the 22mm run cleaner as it will supply a better air supply thats more suited to that carb...Its possible to use an early TV one with the wider neck... but this throws the std jetting way out (Too weak)....Had a similar problem on a mates series 2 fitted with a 25mm dellorto wouldnt run right even after being dynojetted...Changed the air box on that from the LI series 2 narrow neck type.... for the early series 2 TV wide neck type .....then it came too life....back on the dyno and running fine...The choice of carb and air box rely on each other a little...Hope this helps...
Posted: Mon Apr 20, 2009 8:55 am
by simon
cheers J1MS
Yes your right, it won’t run at all with the standard 150 filter, was thinking of using a remote filter as I wanted to keep the original air box in situ
Has anyone used a remote filter on a standard GP200 engine?
Posted: Tue Apr 21, 2009 8:34 pm
by PanosK
Well done Simon.
You have even gone for a ride. I envy you .
I can't fire my S2 up :flaming:
Well done my friend enjoy it.
