Page 4 of 20
Re: water cooled twin
Posted: Wed Aug 05, 2015 9:48 pm
by GBCS
Posted: Wed Aug 05, 2015 11:05 pm
by holty
f24a5ab23142ca75688d26711a33bf1e_zps3z1xjery by
stephen holt, on Flickr
a13e98c9720e524ef1c36fba65ab3d35_zpswyhf7oxt by
ee9b35c78b29c31bc9dba185f16c19d4_zpshkd6iyem by
1577b07dd294133df82a1a6eb4cf048d_zps8gnys9jj by
902af1a183249355b8ea7ce0e9d488c8_zpsapcc4jz5 by
done a bit more to the scoot, fitted the bridge piece,then onto the horncasting and front mudguard, had to trim both in order to clear the brake light switch, a bit of a pain, but i guess thats the price you pay for a custom built scooter, had to take off the headset top to solder a wire i had missed, the switched live for the fuel and temp gauges in the top of the legshield toolbox, will try to do some more tomorrow, hoping to get it running by the weekend, will get a video, im sure those micron exhausts are going to sound sweet. :mrgreen
Posted: Thu Aug 06, 2015 5:31 pm
by GBCS
Temp & Fuel gauges working
Neutral lights and low oil light working
Posted: Thu Aug 06, 2015 5:33 pm
by GBCS
I'm not sure that your speedo is going to be quite sufficient Steve
Posted: Sat Aug 08, 2015 12:34 pm
by GBCS
Just about to try and bleed oil pump,
Posted: Sun Aug 09, 2015 10:31 pm
by holty
i managed to bleed the oil pump, topped up the cooling system through the filler under the seat, fueled up and ready to go. i needed a hand to get the scoot of my workbech, so brother inlaw lent me his ramp, and my good friend andy brought two of his sons to help get it on the ground, success and no damage. it took a while to get it started as the fuel is conroled by 2 vacumn taps, after many kicks it fired up, very smokey at first, i put some premix in the tank, as the oil takes a while to get from the pump to the carbs, had to tinker with the tick-over a bit, but got it to idle in the end.i just had to have a little go down the street,i didnt give it much as it needs running in, clutch is very hard,gears even harder,ive adjusted both and had it in all 6 gears now, more improvement needed,andy took a couple of videos which he will post,
holty
845d2345681f160b563232850a4655fd_zpsamqrruxs by
Posted: Sun Aug 09, 2015 10:54 pm
by ducksta
How do you fit a oil low warning light?
Posted: Sun Aug 09, 2015 10:59 pm
by holty
easy, its a float switch in the 2stroke oil tank, when the oil gets low the float joins the 2 connectors and the warning light comes on, i think the one i used is french, probably a peugeot.
Posted: Mon Aug 10, 2015 9:04 am
by GBCS
First start up with the body work on:
Click the image for the video.
Posted: Mon Aug 10, 2015 11:17 am
by GBCS
First Ride:
It was stuck in first gear, but Steve has now sorted it out.
